Streetfighter head light mount
- Mark Wing
12 Aug 2007 19:22
Hey guys I was looking at that thread and those $200 brackets and thought why not just make some. I guess you guys don't have access to a welder. I found a piece of pipe that was about the right size in the scrape pile at the local metal yard for $5. I also had a pair of the cheep headlight brackets that clamp on the legs. I cut the arms off the brackets and cut the pipe in half and cut some tabs from a piece of plate. After some welding, grinding and some drilling I'll have some brackets for about $30. I'll use a piece of inner tube as a cushion.
Yorba Linda Cal.
Yorba Linda Cal.
- wagonmaster69
- 78 KZ1000A2 / 82 KZ1100 Spectre
Re: Streetfighter head light mount
13 Aug 2007 14:37
What dose the finished peice looks like?
- Mark Wing
13 Aug 2007 18:41
I don't know yet. I didn't have time to weld them up today. I should be able to show you tomorrow. I may send them out with the bumper man and get them plated, not sure on that? He would do them for free so I may.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- Mark Wing
14 Aug 2007 18:36
Well I ended up just making new arms for the light. I only finished one side and I still need to drill the light mount hole. I'm going to do that on the forks to get the light right where I want it. Just using scrap I only have about $10 in it. Looks like I'll make a few to go with the different lights I have for different paint jobs.
These I mig welded The rest I'll tig weld at a friends shop to make them pretty. I'm thing about having them nickel plated, shinny but not too shinny.
Mark
Post edited by: Mark Wing, at: 2007/08/14 21:46
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- galaxian
15 Aug 2007 12:40
Mark want to make one set for a 52mm fork??
1977 KZ1000A1, 1979 KZ650 C3
- Mark Wing
15 Aug 2007 19:05
I don't see why not. Do you know what that is inches? The ones I made fit my ZX7 forks, like I said I'm making more than one set for myself. The rest of them I'm going to tig weld and they'll look better.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- galaxian
16 Aug 2007 07:02
Mark 52mm = 2.047238 inches.
I am using 1996 zx7 forks so yours maybe the same size.
- Jornum1
16 Aug 2007 07:38
I dont know how close the pipe you found is to the diameter of your legs, but why not just use a piece slightly larger (a couple thousandths), and slot it so it can pinch closed on one end? That would give it a cleaner look.
That is what I did for my project. I have GSXR front fork legs. I found a piece of scrap pipe that was close. I did have to bore it out on a lathe to get it right, but it looks really nice. I am sure it wouldnt be too tough to find a piece pretty close. I just used what I had laying around. I understand most dont have a lathe at their disposal. It was just easier for me to throw it int he lathe rather then search through the scrap!
If I can find them in my pile of parts!
I will post a pic.
Post edited by: Jornum1, at: 2007/08/16 10:38
I will post a pic.
- mark1122
- Keep twisting it
16 Aug 2007 08:10
i've been looking for a 52mm. set for zx7 forks too.how hard would it be for u to put something dif on the sides instead of holes?how about a kz or z1 or something?and mabe cut out some of the sleave so it looks like a 2 piece sleave,like the pic below?Am i getting carried away.:woohoo:
Post edited by: mark1122, at: 2007/08/16 11:11
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Mark Wing
17 Aug 2007 07:28
I could cut out some of the pipe to make it look different but cutting a KZ or Z1 in the plate I can't do. I'll check with a buddy who has a sheet metal shop.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- mark1122
- Keep twisting it
17 Aug 2007 08:15
i now a guy with a plasma cutter.that would probably work.but this coud end up costing a small fortune??i'll ask him about it.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
