78 ltd center stand
- udder
78 ltd center stand
10 Aug 2007 09:17
what other years can i find a center stand that will fit my 78 1000 ltd b???? tried kaw crossrefrence but i didnt see any centerstand oem numbers anywhere. someone help a brother out please. much appreciated. chow.
- patmann
Re: 78 ltd center stand
13 Aug 2007 11:56
Just about any 900 or 1000 should work , I would think:dry: I KNOW the 1977-1980 KZ 1000 does for sure. The LTD's didn't come with center stands ( as you know ) but did have the mounts for them UNDER the bike.
You will need the stand and spring plus the two bolts.
And don't let anyone tell you that it won't fit because of your LTD pipes, it will.
Pat
Pat
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
- udder
13 Aug 2007 12:51
thanks for the info. i have vance and hines pipes so it isnt gona clear but all i am wanting it for is to put it up to work on since i have no jack.
13 Aug 2007 15:21
Had difficultly getting the 900LTD onto a center stand, but found this easy method.
Use short length of wood 2x? as a platform with beveled edge or 1x? step-up (I use a square section of 2x12 with 45 deg edge) and roll bike forward so rear tire is sitting on the 2x platform. Bike then easily lifts onto centerstand and platform may be removed.
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
13 Aug 2007 16:00
patmann wrote:
Is this true? Mine (78 B2) has one. So some PO added it to the bike?
West Linn, OR
- udder
- arai59
13 Aug 2007 21:07
Most all pre 78 stands will work. you will havewe to use a V/H stop or make one. This will prevent the stand hitting the header. I like to cut down and reweld the center stand foot peg. It sticks out to far with a header pipe. It was designed for the stock pipes.
- riverroad
- 1980 1000LTD B4
14 Aug 2007 06:57
I bought one off of fleabay last year and I made the mistake of thinking they'd all be the same. The one I got came from a 87 police bike. Different bolt holes, and it's too long. I rigged some big allen bolts to temporarily mount it, and I have to drive the bike up onto some 2X4s to get it high enough to be able to use it. It's a little pain, but it does work.
- patmann
14 Aug 2007 09:27Post edited by: patmann, at: 2007/08/14 12:27
- udder
16 Aug 2007 16:35
well i got one ande it bolts up fine. buttttttt i need a spring for it. any ideas??? since the parts diagram for the b2 shows no spring will another years spring be the same im assuming. looks as though itll clear the headder which is a biggggggg plus and i have vanceand hines 4-1 pipes. where is the problem with those so i dont overlook it and what types of hines pipes have the issues clearing????
- roy-b-boy-b
16 Aug 2007 17:33
Just a standard bike center stand spring will work.
- udder
