16\" rim on 77 kz1000 18\" wheel
- Ironnads
09 Aug 2007 21:36
I'm building a custom bobber that is set up for a kz1000 rear wheel. I have a 77 kz1000 18" wheel, but I want to run a 16" wheel. Can I relace the 18" hub to a 16" rim? BTW I don't want to run a mag wheel. This is only the second bike I've built so I'm still learning the ropes.
- StreetfighterKz
Re: 16\" rim on 77 kz1000 18\" wheel
10 Aug 2007 04:12
You definitely can relace the 16" rim to the 18" hub. It used to be the "thing" to do back in the day. You can get a 16" H@*$%@- D@$#*&^ rim and lace it up. They used to make spoke kits but I'm not sure if the do anymore.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- arobsum
10 Aug 2007 06:52
you could just put an LTD rim on the back. they are 16" from the factory. (i believe anyway)
- StreetfighterKz
10 Aug 2007 08:50
Most older LTD rims are mags and he's looking for spoked. Perhaps you can get a CSR rear rim to work. I believe they're 16" and are spoked.
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- arobsum
Re: 16
10 Aug 2007 13:02
StreetfighterKz wrote:
aahh, i see. oops... sorry about that.:whistle:Most older LTD rims are mags and he's looking for spoked. Perhaps you can get a CSR rear rim to work. I believe they're 16" and are spoked.
Later, Doug
- dutchz
Re: 16
10 Aug 2007 16:24
Buchanan makes spoke kits for a 16"
buchananspokes.com/KawKZspokes.htm
1974 Kawasaki Z1
Stock front hub and rear axle.
- PLUMMEN
