GT501s
- DrWhizBang
GT501s
07 Aug 2007 08:27
Putting new rubber on the KZ650C. Since it seems lots of folks have had good luck with Dunlop GT501s, that's where I'm going. Since I know tire sizes vary a bit from one model to the next, I'm wondering what sizes I should get. Specifically, has anyone had any problems putting a 130/80 on the back?
KZ650C2 w/810CC in Saint John, NB
-- a sleeper, methinks.
- baldy110
Re: GT501s
07 Aug 2007 10:07
I also have a 650C and I run 130/80x18 Gt501. No problems and I really like the tires.
- RonKZ650
Re: GT501s
07 Aug 2007 10:08
I never used the 501s, but used the previous tire in the line, the K591 for 20+ years and no a 130/90-18 will not fit. A 120/90-18 rubs the stock chainguard even. If you remove the guard or use aftermarket then it may fit, but that is a poor solution.
- RonKZ650
Re: GT501s
07 Aug 2007 10:09
Baldy, you must not have the stock chainguard on there with a 130?
- DrWhizBang
Re: GT501s
07 Aug 2007 10:26
RonKZ650 wrote:
Heheh. What chainguard?
My bike is far from stock - the missing chaingurad is only a small detail. I will probably either have to fab my own, or I have no problem modding one when I get one.
- RonKZ650
Re: GT501s
07 Aug 2007 11:12
OK, then I'll say a 130/90-18 will fit then
I'd assume Baldy also doesn't have one or it's an aftermarket one because the chainguard is by far the first thing to rub the tire.
- DrWhizBang
Re: GT501s
07 Aug 2007 11:55
RonKZ650 wrote:
Actually, Baldy appears to have a GS1100 swingarm
Gallery
So I'm not sure how relevant his response is
Gallery
- DrWhizBang
Re: GT501s
07 Aug 2007 20:04
Hmmm. Nobody can confirm that a 130/80-18 GT501 will fit on a 650 with the stock swingarm?
- cafekz750
Re: GT501s
08 Aug 2007 09:22
In Reborn650's signature, he is running a 130 Spitfire on the rear of his 650. You might want to PM him to find out if anything special needed to be done to accomadate this.
Also, on tire manufacturer's websites, they have the specs for the actual tire width and such (130 may only be 128). Atleast, Avon had this info when I ordered tires for my FJ.
Good Luck.
Good Luck.
1981 KZ750H2 - V&H 4-1 pipe, pods, jetted, clubmans, homebrew rearsets, 18" rear wheel and more.
Parting out a 1982 KZ750H3 to fund future projects
2 other non-Kawasaki motorcycles
- baldy110
- baldy110
Re: GT501s
08 Aug 2007 13:36
Before converting to the GS swingarm I ran the 130/80 X 18 tire with the stock swingarm, but I did remove the chain guard years ago.
- DrWhizBang
Re: GT501s
08 Aug 2007 13:39
cafekz750 wrote:
Actually, I currently have a 130 Spitfire on - I just wasn't sure if there is a size difference between the different tires. It's a lot of money to spend to find out it doesn't _quite_ clear.
I didn't know that - I will try to find that info. Thanks!
Good Luck.
