loose caliper
- spectrerob
loose caliper
03 Aug 2007 19:34
Tech help please. I started to notice a little noise coming from the front. The noise went away when I grabbed any amount of brake. When I shook the right front caliper, it moved back and forth a very little bit. I tried to tighten the shaft bolts, but they were tight. I replaced one of the caliper holder shafts to see if that would make a difference and it didn't. The caliper on the other side has just a tiny bit of movement and the back seems to have none. The movement on the right front cannot be a 16th of an inch, but it does seem to be what is making the noise. Is it possible that the caliper holder shaft is worn and the caliper holder needs replaced? The bike is a 1982 KZ1100 D1 spectre with 13,000 miles.
Thanks for your help.
Rob
Rob
- KaZooCruiser
Re: loose caliper
04 Aug 2007 11:00
I have a post on this somewhere in the murky past.
The caliper mounting bolts that secure the caliper to the fork leg are supposed to be isolated from the mounting bracket itself by four isolators (o-rings) that sit inside a recess milled for them. Each mounting bolt gets two isolators.
They dry up / break / go away.
good luck with it
Post edited by: KaZooCruiser, at: 2007/08/04 14:12
good luck with it
- KaZooCruiser
Re: loose caliper
04 Aug 2007 11:09
Hi Rob, I found the post. . .
Rattle sourcing
You might place your machine information in your signature area, so that others with similar bikes to yours can help you pinpoint problem issues.
Rattle sourcing
Re: loose caliper
04 Aug 2007 11:46
Here for reference is the 1982 KZ1100D1 Spectre front caliper diagram from Kawasaki.com
I've never disassembled this particular model caliper, but from looking at the diagram, am wondering if the "BUSHING,SHAFT CALIPER 2" #92028 might be damaged or worn and thereby causing the noise by allowing play in the floating movement.
Ref # Part # Description Qty Spec #
13070 13070-1026
Add to pick list GUIDE,PAD 4
41080 41080-1127
Add to pick list DISC,FR,SILVER 2
43020 43020-1096
Add to pick list PISTON-COMP-BRAKE 2
43041 43041-1062
Add to pick list CALIPER-ASSY,FRONT-LH 1
43041A 43041-1063
Add to pick list CALIPER-ASSY,FRONT-RH 1
43045 43045-1007
Add to pick list SHAFT,CALIPER 2
43045A 43045-1008
43049 43049-002
Add to pick list RING,PISTON SEAL 2
43056 43056-003
Add to pick list BREEDER 2
43057 43057-003
Add to pick list CAP,BREEDER 2
43082 43082-1021
Add to pick list PAD-ASSY,FR 2
49006 49006-1043
Add to pick list DUST SEAL,PISTON 2
49006A 49006-1044
Add to pick list DUST SEAL 4
92001 92001-1951
Add to pick list BOLT,SOCKET,8X30 14
92001A 92001-1355
Add to pick list BOLT,FLANGED,10X41 4
92001B 92001-1510
Add to pick list BOLT,FLANGED,8X25,BLA 4
92028 92028-1090
Add to pick list BUSHING,SHAFT CALIPER 2
92081 92081-1229
Add to pick list SPRING,PAD 2
Post edited by: Patton, at: 2007/08/04 14:49
13070 13070-1026
41080 41080-1127
43020 43020-1096
43041 43041-1062
43041A 43041-1063
43045 43045-1007
43045A 43045-1008
43049 43049-002
43056 43056-003
43057 43057-003
43082 43082-1021
49006 49006-1043
49006A 49006-1044
92001 92001-1951
92001A 92001-1355
92001B 92001-1510
92028 92028-1090
92081 92081-1229
- KaZooCruiser
Re: loose caliper
06 Aug 2007 11:00
so much for my tech help
imagine if he had opened up his brakes and didn't find any o-rings . . .
:laugh:
Patton, your brakes still quiet on the Permatex RTV'd unit?
:laugh:
Re: loose caliper
07 Aug 2007 14:52
KaZooCruiser wrote:
Am pleased to report continuing silent disk brake operation under any riding condition and application pressure. Was lucky to have stumbled onto what proved for me a perfect solution with both Kaws.
...Patton, your brakes still quiet on the Permatex RTV'd unit?
- gpzrox
Re: loose caliper
09 Aug 2007 03:22
My calipers all "float" on the slide pins, and from what my mechanic says and I have researched, this is the way that it is supposed to work.
So if your brakes are like my 84 GPZ's then your calipers should float, and the other calipers pins need to be looked at. Probably just need lubed. I use a pic and lift one edge of the dust boot and put a couple of drops of oil under the dust boots that keep the shafts clean, and let the oil work its way in.
Now for the squealing. Could be anything from the pads not being bedded in properly to needing to have some anit-squeal put on the back to maybe a slightly warped rotor (I have one of these).
But I am pretty sure that your calipers should float, that is why the caliper is a two piece design.
84 GPZ750. Modded with stock Kawasaki parts: ZR-7 shock, ZX-6 coils, GPZ1100 throttle, EN454 brake, GPZ900 fuse box, etc. and non stock: Ken Sears mirrors, K&N filter, Pirelli Sport Demons.
