Bent my handlebars... HELP
- Godzpeed
02 Aug 2007 08:57
Hey I dropped my 80 KZ750 on my lawn when I was testing it and now the right handlebar is bent some which is preventing me from steering it correctly, the fork and everything else is perfectly ok as the handlebars took the pressure. My question is there anyway I can bend the bar back heh I have tried usin a hammer and a block of wood together but that wont work, I have a lot of tools so is there any way I can get this bent back? please I really need help here...
Thanks guys.
Post edited by: Godzpeed, at: 2007/08/02 11:59
Thanks guys.
- flht1997
Re: Bent my handlebars... HELP
02 Aug 2007 09:01
take the throttle off and put a big pipe on it with someone holding the bike?
might work
might work
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
89' BMW R100RT
06' KLR650
- Godzpeed
02 Aug 2007 09:25
Kool man thanks I never thought of that I'll try it when I get home from work today, is the throttle hard to remove?
- phonex98
02 Aug 2007 09:59
nope, two screws. Just lube it back up when you re-install it.
- Godzpeed
02 Aug 2007 10:33
umm did I mention I need to bend the right handle bar towards the front of the bike in line with the left handle bar..does that make sense? basically when the bike dropped it pushed the handlebar in and backwards...yeh im retarded :woohoo: but the frame is fine as usual...let me know thanks so far.
- 76 LTD
06 Aug 2007 15:27
If you try the pipe method you might also want to slide sumthing inside the bars to keep from crimping them like a long 1/2 inch drive extension.if it was mine i would trash them and get new bars as they are soft metal and you can only bend them so many times before they break.if youve ever had the bars break going down the road you know it aint cool.
- donthekawguy
06 Aug 2007 21:03
I would spend the $25 and get a new set of bars.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- barney
07 Aug 2007 06:20
I second that. Get a new set of bars, they are cheap and definately the safer way to go
- riverroad
- 1980 1000LTD B4
07 Aug 2007 07:10
I third that, because by prying on the bar with a cheater pipe, you stand a good chance of screwing up your neck bearings. Bars are cheap and easy.
- arai59
- arai59
07 Aug 2007 11:07Post edited by: arai60, at: 2007/08/07 20:33
- Godzpeed
13 Aug 2007 09:06
cool, yeh I was england for a week but anyway which handlebars should I get for the bike that are comparable and an easy fit for my 1980 KZ750?
Thanks guys
Thanks guys
