650 extended swingarm
  • 77KZ650
  • 77KZ650's Avatar Topic Author
03 Jan 2006 13:56
#15843
I thought that I read something on here about a KZ1000 swingarm fitting on the KZ650, and it being a couple inches longer for a cheap extended swingarm. Is this right? thx
Scott
07 MDP Rookie of the Year
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: 650 extended swingarm
03 Jan 2006 15:13
#15854
I recall that being said before as well. I think it was wireguy who mentioned that.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • wireman
  • wireman's Avatar
03 Jan 2006 17:10
#15865
yes it is ,but i had to change my name to wireman for now!witness relocation,fcc thing!haha i screwed my password up so now im the new improved wireman!anyway the 900/1000 swingarm will bolt on using the stock parts no extra shimming.you can use the 900 arm if you want to keep drum brake,but most 900 swingarms have bushings instead of bearings but you can have them line-bored and install the bearings!1000s have the needle bearings but youll have to make a bracket for the master cylinder.good luck,happy wrenching!
  • PuGz
  • PuGz's Avatar
03 Jan 2006 19:23
#15880
btw you only gane about 1.25" not a big change.
  • wireman
  • wireman's Avatar
03 Jan 2006 19:35
#15883
slide the wheel back in the adjusters and you can pick up another 1"and some change!these swingarms are pretty common and theyre cheap,and you dont have to do a lot of fabrication to make them work.and if youre building a sleeper bike nobodys gonna pay attention to a stock looking swingarm,where as that aluminum suzuki arm will set off the alarms!
  • 77KZ650
03 Jan 2006 20:27
#15889
Thanks for the info. Im not really going for a sleeper, just something you wouldn't expect from a 650. It has a few aftermarket items like a viper fairing, pods, clubman cafe racer bars, and a chrome MAC 4-1 pipe. (getting the 810 kit this spring using the 750 jugs, and doing some head work :) ) I was reading through the archives today about the gs1100 arm. Is it any longer than the KZ arm, or is the only reason for going with it the weight savings over a steel arm? Or can it hold a wider tire? thx
  • Snakebyte
  • Snakebyte's Avatar
04 Jan 2006 00:21
#15896
When I replaced the bushings in my 650 swingarm, they didnt have a listing so they gave me a bearing kit for a 900 swingarm. All I had to do was mill it down some, it was too long. Other then that the bearings pressed right in no problems.
  • wireman
  • wireman's Avatar
04 Jan 2006 06:05
#15913
the suzuki swingarm is about 2"longer than a kz1000swingarm which will make it about 3-1/4" over on a 650 thats an awfull lot of swingarm sticking out back there .they ae nice swingarms but youll have to do a lot more to make it fit.goodluck,happy wrenching!
  • kzcory
  • kzcory's Avatar
04 Jan 2006 08:24
#15933
do a search for baldy on the old site. I'm pretty sure he had a gs arm on his 650
  • Wildog
  • Wildog's Avatar
04 Jan 2006 08:35
#15936
I fabbed one up, here is my bike KZ650 with a 6-inch stretch just finished all the work. Now it may look longer because I chopped off the rear and flipped the tail up, but when it had all of its tail it still looked wicked.
Post edited by: Wildog, at: 2006/01/04 13:39
  • kzcory
  • kzcory's Avatar
04 Jan 2006 12:23
#15980
I stretched a 650 disc brake arm for my 750, but I ended up selling it to another member here...
Post edited by: kzcory, at: 2006/01/04 15:25
  • kzcory
  • kzcory's Avatar
04 Jan 2006 12:26
#15981
pic
