Brake noise question
- Stu Podaso
19 Jul 2007 22:47
This may possibly have an easy answer-
While riding my bike at 'in-town' speeds I can hear a faint ticking sound from the front wheel area(reminds me of the old card in the bicycle spoke noise)
when I apply the front brake.
Is this simply due to the drilled rotor? This is my first bike with disc brakes. My other was an old Yamaha IT 175, drums front and rear.
Thanks ahead for your help.
1980 550 LTD
If it has boobs or wheels your going to have trouble with it.
Man Law
Man Law
- KZQ
- Administrator
Re: Brake noise question
21 Jul 2007 12:42
That sound is totally typical of a driller rotor.
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- The Milkman
21 Jul 2007 14:21
I've never drilled a rotor but it makes sense that, that would cause a noise. I have a question for you guys the have done it though. When you drill the rotors, do you chamfer the holes a bit to maybe avoid getting noise?????
Ride safe.
Ride safe.
- floridamba
21 Jul 2007 15:45
Your brake calipers may have been serviced and the copper spring plate may have been left out. The copper spring plate keeps the pads tight against the brake carrier so they don't go click-click-click at low speeds.
I have rebuilt mine and left them out also, and at slow speeds (up to maybe 15mph) sometimes they make a noticeable clicking noise.
From what I can tell there is nothing to be concerned about. Old Yamaha's however had dual piston brakes and while they would not click, they would make a squeaking shrieking noise to drive you crazy.
- Stu Podaso
23 Jul 2007 18:31
Thanks- I was hoping to hear that. But I will check out the retainer spring soon.
1980 550 LTD
Man Law
Man Law
- KZQ
- Administrator
23 Jul 2007 20:43
Hi Stu,
You said "when I apply the front brake."
Drilled rotors, whether chamfered or not make noise whenever the brake is applied. I've noticed that the noise becomes more noticeable when the pads are worn.
It's not normal to hear any noise from the brakes while simply going down the road.
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
