Tank badges
  • Ozzyzed
  • Ozzyzed's Avatar Topic Author
Tank badges
17 Jul 2007 21:45
#157643
Due to just painting my tank and deciding not to have badges i have just changes my mind!?
Has anyone attached their badges without redrilling holes etc. Have been told to use double sided tape. Any other idea's?
Cheers
Melbourne Australia
1977 z1000A1
'They say people don't believe in heroes anymore. Well damn them! You and me, Max, we're gonna give them back their heroes'!
  • JMKZHI
  • JMKZHI's Avatar
Re: .
18 Jul 2007 05:21 - 03 Dec 2008 10:18
#157688
del
Last edit: 03 Dec 2008 10:18 by JMKZHI.
  • The Milkman
  • The Milkman's Avatar
Re: Tank badges
18 Jul 2007 05:57
#157696
I have no idea how it would hold up to the weather but the thicker foam type that 3M makes would probably work better than the thin stuff they use for carpets. If you went around the edge with a clear silicone, using a toothpick to apply it would help too. Or, have you though about using JBWeld or the two part clay type epoxy they use for gas tank repairs? It comes in a roll about the size of a roll of nickels and won't run the way JBWeld does and works just as good. You pull a chunk of the roll and knead it to together with your fingers to mix it to a uniform gray. I cut the mounting plate off a spare carb I had to make a spacer for my single carb modification and plugged the throttle shaft and other holes with it and it works great.
  • Virii
  • Virii's Avatar
  • I like cheese
Re: Tank badges
18 Jul 2007 07:23
#157720
Yeah, between the weather as The Milkman mentioned, and the inherent spacing you'll get from using thicker tape, I doubt you'll be pleased with the results.
I'd say, gouge out some of your filling, maybe digging under the bracket to get a nice lip (you don't have to get too far in) and use some epoxy to adhere. Seep through your badge holes and under the new lip you made. If you touch up your badge, that'll also give you a nice screwless look to them .
Tess: 1977 KZ650-C1. VM24, 97.5/15/3rd. Dyna-S. Stock exhaust, coil mod performed, BR7EIX.
Angel: 1982 GPz550. Stock. DR8EIX.
  • mariozappa
  • mariozappa's Avatar
Re: Tank badges
18 Jul 2007 07:58
#157726
3M makes trim/molding tape for cars that is 2 sided and about 1/8 inch thick. I have used it in the past with good results. You could probably pick up a roll at Napa.
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • rmmech
  • rmmech's Avatar
Re: Tank badges
18 Jul 2007 11:19
#157758
Its been some time, but I recall my brother using some stuff called 3M Fast Tack Trim Adhesive to re-attach lighter metal trim pieces to his mustang when he repainted/restored it. Couldn't hurt to read up on it to see if it would work for you.
Unlike the tape mentioned earlier, this is in a tube.
good luck.
Post edited by: rmmech, at: 2007/07/18 14:24
  • mariozappa
Re: Tank badges
19 Jul 2007 05:40
#157897
When I got home last night, I actually measured the thickness of the tape. It's 1/16th inch, not 1/8.
:pinch:
1977 KZ650C1
  • Ozzyzed
Re: Tank badges
19 Jul 2007 17:03
#158084
Cheers mate
Melbourne Australia
1977 z1000A1
