gpz sprocket change
  • eel
  • eel's Avatar Topic Author
gpz sprocket change
17 Jul 2007 07:39
#157410
is there a sprocket cross reference somewhere..
what bike uses the same output shaft/offset and rear sprocket as my gpz?
the reason im asking is because i want to do a 520 conversion but i cant seem to find 520 kits for a bike this old but maybe for a newer bike with the same style of sprockets?
1984 GPz750
2007 ZX6R
53-Racing.com - My Website
My GPz
  • Fossil
  • Fossil's Avatar
Re: gpz sprocket change
17 Jul 2007 10:19
#157432
You can use the charts here to determine spline and offset. Easy conversion doing the 530 swap, don't know 1st hand how easy it will to find a 520 sprocket with the correct spline.
www.jtsprockets.com/
  • eel
17 Jul 2007 10:27
#157436
530 is good for me... ;)
seems like the sprockets only fit ZX750 (gpz) and nothing else.. ideas on who makes 530 sprockets for it then?
1984 GPz750
2007 ZX6R
My GPz
  • archemitis
  • archemitis's Avatar
17 Jul 2007 10:37
#157443
i have 530 sprockets on my 77kz1000 i ordered them out of the street catalog, they list them for the kz. cheap and easy to find chains too.
  • steell
  • steell's Avatar
17 Jul 2007 22:04
#157645
Bad news :(
No one makes a 530 conversion (or 520 for that matter) for a 83-85 GPz750. I spent months looking, and finally lucked into two 530 sprockets that were left over from a group buy on the GPz750 mailing list from PBI, and PBI says they will no longer make them.
I even contacted all the sprocket manufacturers.
The problem is that the 83-85 GPz750 uses an offset sprocket stock, and no other bike uses the same sprocket.
You might contact the people that make the offset sprockets for the 1000's and see if they will make one to match the GPz750 offset, or get a new sprocket of whatever size you want, and take it and the original sprocket to a machine shop, and ask them to cut both sprockets then weld the new sprocket outside part to your original sprocket hub, but that's going to cost $$$.
You just have to be creative when dealing with finding parts for old bikes :)
Pic of the GPz750 sprocket from JT
My nephew has one of the two 530 sprockets on his GPz750 motored KZ650 SR, and he has the other locked up in a safe deposit box somewhere, he's not letting it get away :D
Post edited by: steell, at: 2007/07/18 01:12
  • eel
18 Jul 2007 04:34
#157670
thanks for confirming it.... thats what i was beginning to see..
1984 GPz750
2007 ZX6R
My GPz
  • Fossil
  • Fossil's Avatar
18 Jul 2007 22:07
#157869
You could have the teeth turned off a stock 630 sprocket, the centre turned out of a 520 or 530 sprocket, and have the two welded together with the amount of offset required.
  • myelr21
  • myelr21's Avatar
20 Jul 2007 03:52
#158203
for a flat 530 use the 99-2000 zrx 1100 it will go straight on and for the offset sprocket go the early zx11 dished sprocket its also 530 and is what i have on my 81 gpz1100 to line up the chain with the 4.5inch wide gsxr wheel.B)
07 zx1400 candy blue pc3 dual staintunes.
project z1000j, gpz1100 engine, 1400 big block mtc, kerker with race baffle, 37mm keihin cr specials, gsxr1100 usd front , gsxr 1100 monoshocked rear.
  • myelr21
  • myelr21's Avatar
20 Jul 2007 03:56
#158204
  • Fossil
  • Fossil's Avatar
20 Jul 2007 10:50
#158273
The 750 and 1100 GPZs turn out to have different splines, not interchangeable as I had thought myself.
  • myelr21
  • myelr21's Avatar
20 Jul 2007 14:30
#158319
bugger.:(
  • myelr21
  • myelr21's Avatar
20 Jul 2007 14:31
#158320
bugger.:(
