new chain and sproket
  • oldkaws4ever
  • oldkaws4ever's Avatar Topic Author
  • Have no regrets...... You only live once.
14 Jul 2007 21:15
#156877
i figured i would go out for a ride today, i ended up stopping at a bike shop that only works on old kawi's. An all origanol 74 Z1 900 cought my eye, I ended up getting a free oil change because i know the owner, and there were no customers. Now for the bad news, i need a new chain and sproket's, so i had him order them. It's going to be $180.80 for a new 630/92 chainn and a 15front sproket and 35 rear. But the killer is the service rate is $80.00 and hour and he said it would be like an hour and halh, So it's going to be like 120.00 in labor. So 300.00 all together.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • ejshotgun
  • ejshotgun's Avatar
Re: new chain and sproket
14 Jul 2007 22:04
#156880
$97.20 Chain
$29.00 RearSpr.
$13.51 FrontSpr.
The above is for a '74Z1900 from Z1Enterprises
and if I can do it then anyone can change these (though I went w/530 chain).
Post edited by: ejshotgun, at: 2007/07/15 01:04
  • oldkaws4ever
14 Jul 2007 23:47
#156895
ya 80.00 an hour is kinda steep for me, im going to give it a shot myself. From what i have heard it is easy to do the chain and sproket swap. I was reading up on the z1 900 chain and read that it was an endless chain with no master link?, if so can i just use my trusty dremmel to cut a link of chain in half? Or does the swingarm have to come off?
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • katjbus
  • katjbus's Avatar
15 Jul 2007 01:39
#156907
you can cut the chain, but you will need a riveting tool to put the new one back together, maybe your buddy will loan it to you it only takes a few minutes
  • floridamba
  • floridamba's Avatar
15 Jul 2007 07:32
#156918
I use a grindstone on my drill and grind off the peened-over rivet ends on a sideplate. the key is to do this against the rear sprocket so it doesn't wiggle all over the place.
Take a small chisel (or old flat screwdriver) and push it in between the outer plate and inner links and the side plate should pop off. It may come off with a lot of force so be careful, wear safety glasses, etc.
Sometimes it takes a whack from a hammer on that chisel to get it off.
I just ordered my 530 converson from Z1Ent...
If you search on 630 conv you will see a link explaining it and how to determine what sprockets you need for the job.
  • oldkaws4ever
15 Jul 2007 17:56
#157005
thanks for all the info guy's. I think it should go together pretty easy. i have done a sproket and chain change on my dirtbikes before, and that was easier than i thought. I always hate the idea of somebody else working on my baby, even though all the guys at this shop were kawi mechanics back in the 70's, i just like the fact of knowing the job was done right, and nothing was comprimised. Im sure the majority if not all of you guys feel the same way.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • oldkaws4ever
19 Jul 2007 13:48
#158022
well i just got my sprokets and chain on, and what a difference. I took it on a 35 mile ride or so, when i lay into the throtle she pulls like a freight train, and it is so much quieter now that the chain isint bouncing up and down. Also when i rad the rear wheel off i went ahead and replaced the bearings, now the rear wheel spins so freely
Post edited by: oldkaws4ever, at: 2007/07/19 16:49
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • ejshotgun
19 Jul 2007 16:13
#158063
Sweet!!!!
Happy Riding
