making another change wheel question
- donthekawguy
07 Jul 2007 06:23
ok here I go again. I'm looking to put a set of cast wheels on my bike. I need to knnow what will bolt on for the front as in gsxr or similar. The back will be easy as I can fit up to a 190 in the swingarm I have. I need 17in or smaller to make it easier to get street legal drag tires. For the front I need bolt a bolt on wheel and I can fab up a caliper bracket.
Post edited by: donthekawguy, at: 2007/07/08 00:27
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- StreetfighterKz
Re: making another change wheel question
08 Jul 2007 12:54
Don,
What front end setup do you have? If its a normal Kz, I don't think alot of 17" rims are just going to slip right in. The fork tubes are usually not far enough apart for the wider hubs. I have seen one bike that had a standard Kz front end with a 17" katana rim but the guy had to do alot of work to make it fit.
If you have police front end, like my 1000, that'll help you out.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- donthekawguy
11 Jul 2007 05:56
I have the stock front end. I have a 5 inch wide 18 inch rear wheel but I can't find a street/drag tire that will fit. Argg!
Post edited by: donthekawguy, at: 2007/07/11 08:56
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- StreetfighterKz
11 Jul 2007 08:38
Don,
Dunlop has a D220 available in a 170/60-18 and they have a matching 120/70-18 that you would only have to relace your front rim to make work. The D220 is considered a sport touring tire but they came stock on the Yammie Road Star Warriors and the Kaw Mena Streaks.
The 170 on a 5" rim should lay a pretty nice footprint for the strip.
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
