Damper Rod Tool for a 1300
- KZQ
- Administrator
06 Jul 2007 23:35
I recently decided to give up and admit that the fork seals were leaking. On other bikes, I had previously successfully used an impact driver to loosen and remove the bolt from the bottom of the damper rod but not on this bike. The bolts are bigger and the damper rod seems not to have enough inertia to keep it from spinning. I had managed to disassemble both forks but I was only able to get one to tighten up on reassembly. So after some wasted time I decided that I needed to disassemble a spare fork tube I had so that I could see just what it is that that special tool is that Ma Kaw suggests.
Check out a 15/16" hex bolt welded to a piece of 1/2" EMT conduit:
It works fine! I welded a bolt on each end so I can use a socket drive to keep the damper rod steady.
Here it is in the fork:
kzcsi
kzcsi
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- Mcdroid
- Gone Kwackers
Re: Damper Rod Tool for a 1300
07 Jul 2007 03:16
Congrats...necessity is truely the mother of invention:)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
