Engine Forum
Engine forum is a tech forum for "Engine" topics.
Will tail section from other 650s fit on an 81 CSR?
  • storysunfolding
  • storysunfolding's Avatar Topic Author
01 Jan 2006 06:22
#15492
My project bike is an 81 650 CSR. Will a tail section from another bike like this kzrider.com/component/option,com_joomlab...unc,showcat/catid,5/ fit well on the CSR? I like the look of it, and I the sketches I made with it in my paint scheme look amazing.
The goal is to have it up and running (no problem), bastardized a bit with new wheels with two front discs and one (new swing arm, another kzs front end with dual disc setup, and whatever I make work in the back), the tail section, and then a custom paint job. It's going to be the best graduation present anyone's ever gotten. Any help and suggestions that will make it neater would be appreciated and once I get started I'll be sure to give you guys lots of pictures :)
Post edited by: storysunfolding, at: 2006/01/01 10:14
  • NightRider
  • NightRider's Avatar
Re: Will tail section from other 650s fit on an 81 CSR?
01 Jan 2006 16:38
#15527
You will have to cut and trim a bit, as I had to do for my CSR. I am using '78 tail plastic. I believe you can see a pic in the 650 forum, has the gold front wheel and in pieces. The plastic is the same width as the frame, though, easy mods...
Post edited by: NightRider, at: 2006/01/01 19:39
