sport bike swingarm
  • jordan
  • jordan's Avatar Topic Author
sport bike swingarm
26 Jun 2007 11:25
#152867
I have a 1982 kz750, and I really love the bikes i see with the newer sport bike swingarms. I have been looking through the archives and have got many ideas, but I have many unanswered questions.
I have been searching around and have found many newer model gixxer swingarms. Can these be easily modded to fit. Fitting either a monoshock, or dual shocks shouldnt be a problem.
One of my major questions is what would you do with the front sprocket so that it would work with the wider rear wheel?
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold :(
1972 Kawasaki s2 350-parted on ebay :(
1973 Kawasaki s2 350-parted on ebay :(
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
  • steell
  • steell's Avatar
Re: sport bike swingarm
26 Jun 2007 16:39
#152940
I just finished (last night) putting a 99 GSX600F (Katana) front end on my 80 KZ750E, and am now working on the swing arm. The 99 GSX600F has a steel boxed swing arm, and it's about 4" longer than stock. I didn't want all that extra length, and I'd rather shed some weight, so I'm using an aluminum swing arm off a 83 GPz70, it's about 1 1/2"-2" longer than a KZ750E swing arm, and the axle is the same size as a GSX600F so I can still use the 4 1/2" wheel.
I'll probably get back to work on it in a couple of days.
Oh yeah, I'm sticking with dual shocks.
Post edited by: steell, at: 2007/06/26 19:40
  • Snakebyte
  • Snakebyte's Avatar
28 Jun 2007 04:42
#153343
Offset engine sproket will do the trick.
  • jordan
28 Jun 2007 09:05
#153397
has anybody ever tried this using a newer gsxr swingarm?
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
  • Fossil
  • Fossil's Avatar
28 Jun 2007 10:02
#153416
Regarding offset sprockets, you can use the JT sprockets chart to find a spline that matches your bike's and hopefully an offset that will give you the clearance required
www.jtsprockets.com/
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
28 Jun 2007 13:57
#153474
ape and kosman make offset sprockets.make sure to check the swingarm pivot tube as to inside diameter and length.you might have to get a fabricator to build you a new pivot tube to make the conversion.i've seen several done and if done right they look cool and are safe.i am fixing to put a zuke wheel under my z1r.but i am custom building my swingarm out of chromoly,and building my own pivot tube and re-using the axle plates and axle's off of the zuke.another crazy thing we do is turn the center out of one sprocket and turn the outside off of another sprocket and build spacers and weld em all back together to create are own offset sprockets.having my own fab shop helps tho.
