KZ1000 chain tension
- jeffcool326
24 Jun 2007 13:25
Hi, I just put a new chain on my 1981 kz1000m bike. How much tension should i have in the chain. Thanks To All Jeff
- kzwolfsr
Re: KZ1000 chain tension
24 Jun 2007 13:39
You measure tension by taking the chain in the center, between the front and rear sprocket, the part where the chain has a belly hanging to the floor and there should be a half of an inch of movement.
Original man of the Caribbean
- The Milkman
24 Jun 2007 13:55
If you didn't replace the sprockets, or if you did for that matter, with the bike on the center stand turn the rear tire till the chain is at it's tightest position and do the adjusting at that point.
Ride safe.
Ride safe.
