KZ750 forks
- Invicta 39
KZ750 forks
22 Jun 2007 08:38
I have just purchased a 1982 KZ 750 and I see that it has a place for airing the shocks; does anyone know what pressure to set these at?
- OKC_Kent
Re: KZ750 forks
22 Jun 2007 10:49
I don't know the pressure, but it will be in my manual at home. Can you wait until tonight? I believe it is a few pounds and a small hand pump is used, as the pressure is low.
Whatever you do, DO NOT take it to the air pump at the gas station or some home compressor or you will be regretting it.
Cashion, OK
78 KZ650 B2 85,000+ miles
- mariozappa
Re: KZ750 forks
22 Jun 2007 10:55
I think minimum pressure starts at 7 or 8 psi.
And if your not a big guy, that may be all you need.
1977 KZ650C1
and the KZ650/KZ750 Conversion
- drkaw
Re: KZ750 forks
26 Jun 2007 12:11
I have a 1982 KZ750 E2 (Standard), 12 psi works well. I think 18 psi is max.
