Looking for swing arm set up
  • Snakebyte
  • Snakebyte's Avatar Topic Author
30 Dec 2005 04:47
#15173
I have a 1977 KZ 650 I want to mount a new or used swingarm on it that will hold a 160 or 180 tire. I also want to have a little extension to it, 22 to 25 inches long from pivot to ecentric. Disc brakes with master are needed to. Any Ideas to what will fit that I can purchace. I have about $230 to spend.
The pivot point on the frame is around 9 1/8 inches. If i need to go to a mono shock that is no problem. I'm also looking for the rear adjustment to be the rotator type like the gpz.
  • RomSpaceKnight
  • RomSpaceKnight's Avatar
Re: Looking for swing arm set up
30 Dec 2005 10:46
#15240
Early GSXR swingarms might work. Typically get 3" over on length. Popular mod for KZ in my town. Twin shock mounts can be welded on. A 750 triple swingarm might be a cheaper option. Not sure if you could get a 180 tire in it though. Maybe a 160.
  • Dave Sloan
  • Dave Sloan's Avatar
30 Dec 2005 14:36
#15285
I have a suz gsx 1100 swingarm on my 650, wasnt a great deal of hassle to fit it, I have a150 on it at hte moment but a 160 will fit no worries but I dont think that you will go much bigger than that. I have used the stock 650 axle and changed the bearing size to fit, also had to machine up a few spacers as the 1100 swingarm is shorter than the 650 one is between the frame, I ll take a few pics of the arm if you wanr.
Cheers
Z650B2 - Injected
  • kawtoy
  • kawtoy's Avatar
30 Dec 2005 15:05
#15287
Remeber that a wider tire usually needs a wider rim. That will inlolve getting a extender front sprocket so that your chain will still be alligned.
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
  • Snakebyte
31 Dec 2005 02:06
#15358
Thanks for the replies guys. I didnt think about the chain might need to be moved. If you guys have pics please send them. I need I ideas, and most important a swingarm setup.
  • galaxian
  • galaxian's Avatar
31 Dec 2005 10:30
#15411
If you want to run a 160 tire you could pick up a zx6 4.5" rim which will hold a 160 tire. As far as the swingarm goes a suzuki gs1000sz (katana)from 82-83 or a regular gs1000 has an aluminum swingarm which will bolt right in with only two washers on each side to take up the space. This is what i am running on my bike. The only thing you will need to change is the rear wheel bearings and the rear caliper bracket. The small kz (650/750) have a 17mm rear axle where the larger brothers have a 20mm. The suzuki also has a 20mm axle. If you go into the archives i did a write of with pics of everthing you will need for this conversion.
1977 KZ1000A1, 1979 KZ650 C3
  • donthekawguy
  • donthekawguy's Avatar
31 Dec 2005 11:36
#15420
I still have a swingarm and brake set up from a 83 gpz750. Let me know if you want me to measure it.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • lowbuck
  • lowbuck's Avatar
31 Dec 2005 14:26
#15444
galaxian: it appears the links to your pix in archives are broken -- care to repost more shots of your too cool setup?
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
01 Jan 2006 06:06
#15489
I have a GSXR Mono Shock setup. The pivot point is
9 7/8 in. and approx 23 in. from pivot to axle. I have the shock,mounts,and the rear brake caliper and master cylinder.
If you want pictures i'll have to email them as i am not able to upload pictures from my computer.
I'm leaving for the Boston area and will be home this weekend. Roy
Post edited by: roy-b-boy-b, at: 2006/01/01 09:08
  • Snakebyte
02 Jan 2006 05:30
#15601
I found a setup that I'm interested in. All Ineed is the inbetweens. Like cush, brakes and master, spacers chain and sprockets, chain gaurd for swing arm and wheel, ets heres a pick. If shipping is duable I will have it in no time.
Found a master cylinder setup on line ffore 39 bucks from a 05 zx6 includes the caliper, master, lines, and resovore.
  • Snakebyte
02 Jan 2006 05:31
#15602
Here it is
  • Snakebyte
02 Jan 2006 05:34
#15603
on line item
