KZ305 sprocket question
  • sorner
  • sorner's Avatar Topic Author
20 Jun 2007 12:37
#151178
Everything I found online says my stock KZ305 has 15T front and 33T rear sprockets. I am running at 6000RPM at 55MPH. I'd like to tone that down a bit. I found a 16T front sprocket from Z1 for $10.99. Based on fomulas I found, that'll get it down from 6000 to about 5600. Is there any way to get that down a little bit more closer to 5000? I'm not concerned about the giddy up off the line, I'm a gas thrifty rider and I want economy over speed, after all it IS only a 305 so I can't expect it to launch like a rocket anyway!!!
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
Re: KZ305 sprocket question
20 Jun 2007 16:54
#151242
The sprocket from a Z-1 will not work it is a totally different mounting system. The 305 uses the same type of attachment system as the 550 though so it is possible that might work. I have both a 305 and several 550's so I'll check it later and let you know for sure. I don't think you will want to go more than 1 tooth up though going up 2 will put the gearing way too high I'm afraid.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
  • The Gringo
20 Jun 2007 17:31
#151258
Okay I just checked this out. The stock sprocket from an 81 550 LTD is a 16 tooth and it will bolt right on with no problem the countershaft is the same spline and uses the retainer that is held on with 2 6mm bolts. Just to make sure I ran the chain around it to make sure it wouldn't bind on the cover or anything seems like it will work ok, it is a tight fit so using anything bigger is out of the question but this should drop your RPM's a bit. Now we both know.;)
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
  • The Gringo
20 Jun 2007 17:35
#151262
DOH.... I just re read your original post and noticed you were talking about Z-1 Ent. and not a Z-1 model.....:blush: :blush: :blush: Never mind!
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
  • udder
  • udder's Avatar
20 Jun 2007 17:39
#151263
cant deny the effort though gringo ;)
  • sorner
20 Jun 2007 18:46
#151293
Yeah, I was talking about Z1 ent... thanks for the stellar effort though!
  • sorner
26 Jun 2007 03:40
#152750
Just to follow up and left everyone know, I received the new 16T sprocket from Z1 Ent. and installed it last night and went for a ride. It makes a big difference actually. It's barely noticable "off the line", but 6th gear is nice, it's basically like having 7th gear. My bike now does 60MPH at just under 6000 RPM's. I went up some hills and it didn't really bog down too much more than it did before. Just going 65 before to keep from getting ran over on the highway was taching 7500 before, which made me nervous that the engine was just going to fly apart and take my legs with it. Thanks for all the help!!!!
  • donthekawguy
  • donthekawguy's Avatar
26 Jun 2007 04:30
#152755
If you need to you can always go a couple teeth smaller in the rear without having to shorten the chain.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • sorner
26 Jun 2007 05:11
#152762
I haven't found anything smaller than the stock 33T for the rear though, I've found bigger, but not smaller. I wouldn't go more than 1 tooth though, it might bog down too much.
  • The Gringo
26 Jun 2007 05:22
#152763
Sorner thanks for the followup. I don't ever see myself riding my 305 on the highway (too many other bikes that work better for that)it still is good info to know. My stepson is only 13 so it will be a few more years before he can legally ride but possibly then this might be a good mod to make.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
  • sorner
26 Jun 2007 05:25
#152766
I don't either, if I ever go on the highway it's just to go one or two exits just to avoid traffic... but if I do that I don't want to get run over! LOL! I don't know how far torn apart your 305 is, but I noticed a metal shield around the housing outside the sprocket on mine, I dont know what's behind it but if that can be removed it would take a 17T sprocket on the front. I'm not going to get into that because I'm satisfied with the results going to the 16T.
  • The Gringo
26 Jun 2007 05:57
#152771
Removing that little shield would not be a good thing to do because in the event you snap your chain it could really damage the crankcase. My 305 is actually pretty much all together I'm not too sure yet if I can get it out of the basement that way though. I may have to take it apart, carry it up and re assemble it again :pinch: . Here is a pic as it currently sits.
Post edited by: The Gringo, at: 2007/06/26 09:00
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
