Changing fork oil and seals - KZ1000LTD
- floridamba
18 Jun 2007 18:23
I am changing fork oil on my '82 KZ1000LTD and probably the seals too. I bought the bike used and put some air in the forks and it started weeping oil slightly. I took the air off and it doesn't leak now.
I've ridden it a thousand miles since then and no leaks- is this an air problem or are my fork seals ok? It's easier to do just the oil versus the seals too.
thanks
David
thanks
David
- PLUMMEN
Re: Changing fork oil and seals - KZ1000LTD
18 Jun 2007 18:27
id change the oil and the seals;)
- neilage66
18 Jun 2007 18:44
A wiser man than I once said: "An ounce of prevention is worth a pound of cure"
Heavier fork oil (say...20w) might give you a fork that *felt* like it had air pressure, but doing the seals is probably a good idea if they were leaking under air pressure.
Disclaimer: This advice comes from a guy who taped a rag onto his fork top to soak up seeping oil for several months until he got around to changing out the seals and oil. :whistle:
Figure about half a day and 25-30 dollars for seals, boots and oil. Have some snap ring pliers handy too...and a vise.
Post edited by: neilage66, at: 2007/06/18 21:46
- floridamba
19 Jun 2007 07:28
Thanks for the input.. I will probably go and do them anyway while I have it up on the lift.
thanks
David
thanks
David
- kzwolfsr
19 Jun 2007 12:31
I had to do the same thing with mine Neilage.
Original man of the Caribbean
- neilage66
19 Jun 2007 16:31
kzwolfsr wrote:
I assume you're referring to the *ragamuffin method* ? :laugh:
Quick...hide the evidence!
Carp! almost slipped up and posted a pic in the chassis forum...bad biker/no donut.
Guess we'll have to use our imaginations. :whistle:
Post edited by: neilage66, at: 2007/06/19 19:34
