Siezed front axle nuts
- old650
16 Jun 2007 12:00
Sorry, don't have time to search archives. My front axle nuts are siezed tighter than a nun on a saturday night. I want to change the tire and install new bearings etc. Any tips? Again I apologise for being lazy, I usually make the search effort but I'm under the gun for time. Thanks. They will sit with liquid wrench on them for a day or two. What I really need to do though is get it inside the hub somehow. Gotta go!
Post edited by: old650, at: 2007/06/16 15:03
- PLUMMEN
Re: Siezed front axle nuts
16 Jun 2007 12:12
loosen nuts on caps,then put a big wrench on each side;)
- OKC_Kent
16 Jun 2007 13:50
I had the same problem, do what Plummen said. I also needed a pipe on one side.
Cashion, OK
78 KZ650 B2 85,000+ miles
- RonKZ650
16 Jun 2007 16:01
Leave the pinch nuts tight on one side, then put a BIG wrench on the other. The tight pinch nuts will hold that side from just turning so all your effort goes into the side you're working on. Whichever side of your axle is less frozen will break loose first, then you loosen the remaining pinch bolts and you're good to go.
- PLUMMEN
16 Jun 2007 16:17
RonKZ650 wrote:
thatll work too!Leave the pinch nuts tight on one side, then put a BIG wrench on the other. The tight pinch nuts will hold that side from just turning so all your effort goes into the side you're working on. Whichever side of your axle is less frozen will break loose first, then you loosen the remaining pinch bolts and you're good to go.
- old650
17 Jun 2007 02:54
Thanks for the tips guys, I'll get at her when I have some time off work. I was using a very BIG breaker bar with a 27mm socket on it and the bloody bar was flexing a bit, but no go. Maybe some pipe would give me more leaverage. I have a spare front wheel if anything goes pop anyway. I was also able to take the nuts/axle apart on my spare, but my runner is being nasty. I'll rub its tank and talk nice to it, maybe it will cooperate.:lol:
Post edited by: old650, at: 2007/06/17 06:02
- old650
22 Jun 2007 19:51
I got the axle nuts off with an audible POP, after that they just came off like butter. I wanted to see the condition of the front bearings and they were still well greased. Anyway, I got the tire off, took the axle, seals, bearings etc. out of the wheel. The rim has been sprayed inside and out to free the spokes. I'll tighten up the spokes, check the rim for true, clean it all up and install new bearings (that I repacked with moly grease). It will feel good to have the new tire/tube/rim strip and bearings in the front end. I already installed new rear bearings so the war pony will have firm legs for a while.
Now maybe I'll get around to that leaking right fork seal one day. I've had the new seals since last year. :whistle:
