Crazy new bleeding technique
  • vach
  • vach's Avatar
Re: Crazy new bleeding technique
12 Jun 2007 19:33
#148862
Put fluid in the master cylinder and then put the syringe with the tubing on the bleeder and suck or vacuum the fluid from the master.
1979 kz650 B. Chicago, Illinois
  • smd
  • smd's Avatar
12 Jun 2007 19:49
#148868
vach--if I use the syringe to suck, do I need to tie down the lever?
  • Night_Train01
  • Night_Train01's Avatar
13 Jun 2007 04:11
#148937
it doesn't matter if the lines are new it works the same. Draw a bunch of fluid into the syringe, attach it to the bleed nipple, remove the cover from the master so you can watch when the res is full. Open the bleed screw and press on the syringe. Don't press to fast as you don't want to shoot brake fluid out of the res, just keep pressing until the res is full and tighten the bleed screw....your done;)
  • smd
  • smd's Avatar
14 Jun 2007 17:00
#149483
I'll try it again just as soon as I get back the lines I had to return to Galfer because they leaked. Total mess. Thanks for the tips.
  • katjbus
  • katjbus's Avatar
14 Jun 2007 17:24
#149499
The technique you talked about in your first post works awsome on car master cylinders, I have never tried it on a bike though, usually just use a mighty vac
