Suspension
  • budzilla
  • budzilla's Avatar Topic Author
Suspension
10 Jun 2007 20:40
#148161
I've seen a bunch of late model sportbike front ends and swingarms installed on KZ's. Are there any particular year and model parts that bolt up or perhaps require less machining/fabrication than others to make work? Seems like some of these parts may just require a bearing and/or spacer swap. I have an 81 KZ1000CSR and any guidance regarding this matter will be greatly appreciated!
Post edited by: budzilla, at: 2007/06/10 23:42
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
Re: Suspension
10 Jun 2007 21:04
#148171
From what I've seen and heard, a Suzi GS1100 swingarm is the prefered choice.
The front end is an entirely diff matter, and usually ends up being what's personally preferable and available. And if complete with wheel and brakes, that makes it all the better.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
  • wireman
  • wireman's Avatar
Re: Suspension
10 Jun 2007 21:14
#148183
82 gs1100e;)
  • shaftie1100
  • shaftie1100's Avatar
Re: Suspension
11 Jun 2007 14:48
#148441
91' GSXR 1100 front end conversion:
Use a 90's GS 1100 steering stem, but put new roller bearings in. They're worth every penny.
I just got my front rim back from the powder coater and put back together last weekend. I still have to clean up some of the misc. odds and ends on the front.
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
Re: Suspension
11 Jun 2007 21:27
#148562
You can get any front end "on" that you want. The easiest way will be to make sure you have the complete clip (triple on down) and then have a shop press the stem out of the new stuff and put your KZ stem in the new triple. The new triple will probably be bigger so the shop will need to make a bushing to fill in the difference, then weld the stem in place. A custom top bushing can be made to take up that slack also.
I've done it on my 'J' and am in the process of doing it again to an ELR clone that I have.
I've gone the route of parting together a front end and it ended up costing me waaaaaaay more by trying to cheap out. Just a warning...get a complete front end.
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
  • RollingStock
  • RollingStock's Avatar
Re: Suspension
22 Jun 2007 15:07
#151841
i went 90's fzr600 frontend.. swaped right over with the use of aftermarket bearings.
01 zx12r swing/arm was pretty easy too...
73 z1900 street nitrous drag bike(powered but honda)
83 kz750 turbo street fighter project
