Fork oil
- 2bskor
Fork oil
09 Jun 2007 15:29
My Clymer manual says to use 10w non detergent fork oil, my question is I have 10w non detergent oil not "fork oil" Is there a difference or could the regular oil be used?? The oil in there now looks like it is red or pink.
Also if anyone ever replace oil in a kz1000st/e1 ids the fork springs under load ??
1979 KZ1000ST (Canadian) Electronic Ignition, 4 into 1 header,K&N air filter
- wireman
Re: Fork oil
09 Jun 2007 15:47
take the weight off of frontend,there will still be a little pressure on caps when you unscrew them.motor oil is fine;)
Re: Fork oil
09 Jun 2007 16:19
I would suggest you use a quality "Fork Oil" such as Bel-Ray rather than motor oil. Fork oils are formulated especially for forks including additives that preserve the seals. I've changed the fork oil in my '77 KZ650C1 every 2 years since it was new using 15w Bel Ray fork oil and have never had any seal leaks or other issues. I figure a couple bucks every 2 years is pretty cheap insurance. The 15W makes the ride a little stiffer, but I find that to fit my riding style best. Ed
Re: Fork oil
09 Jun 2007 16:39
2bskor wrote:
May be automatic transmission fluid. Some folks regularly use ATF in their forks.
... The oil in there now looks like it is red or pink.
- wireman
