battery box
- hobodan
battery box
08 Jun 2007 19:16
Quick question; I looked at the diagrams Kawasaki had, but i was just curious if there is a spacer between the battery box and the frame? perhaps my bolt is just not small enough... It's a '77 kz650-b1. Also, do you know if they sell a bolt kit for the whole frame? A lot of them are old and rusted. Perhaps I will have to individually get them... Thanks!
-Dan
-Dan
1977 KZ650-B1 frame and engine. Random pile of parts for the rest.
Re: battery box
09 Jun 2007 02:02
hobodan wrote:
Perhaps already seen the kawasaki.com diagram. Not sure about tranferring it here, but will try. Am uncertain, but appears to bolt directly to a frame tab with no spacer. Don't understand the bolt size fitment issue. A bolt head should not be rubbing against the battery. Battery should rest freely inside the case, protected on bottom and sides by the rubber bumpers. Some slide in from the top (eg., Z-1)
and others from the side (eg., KZ900).
Post edited by: Patton, at: 2007/06/09 05:05
-Dan
- hobodan
Re: battery box
10 Jun 2007 23:04
Thanks man! I found out what the problem was, i wasent using the right bolt and enough washers. And the bolt numbers mean this:
6x12 <--> 6mm diameter and 12mm length measuring from the bottom of the head to the end of the bolt.
8x60 <--> 8mm diameter, 60mm length
and so on.
Also, i have a lead on someone who might do a whole bolt kit for anything that attaches to the frame.
Thanks again!
and so on.
Thanks again!
- bill_wilcox100
Re: battery box
11 Jun 2007 05:00
I'd be interested in knowing how the bolt kit works out. I might want to do the same thing. Could you post back to this thread with your findings?
Best of success.
Best of success.
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Upgrades:
Montreal, Canada
- BSKZ650
Re: battery box
11 Jun 2007 05:39
if you find someone who will do a bolt kit, let me know also, it woul save a lot of time at the supply house
77 ltd1000, current rider
76 kz900, just waiting
