Factory rake
- fuzzwardo
Factory rake
08 Jun 2007 07:05
how does the motorcycle manufactures determine what they will use for the degree of rake on their bike? Would there be a problem with de-raking a bike ( less degrees at the head than choppering it out)?
1978 Kz650B
2001 ZX9R
1996 zx9r project
1985 Suzuki SP250
1991 Harley Electra-glide classic
2001 ZX9R
1996 zx9r project
1985 Suzuki SP250
- Fossil
Re: Factory rake
08 Jun 2007 08:13
If you derake your frame, you will reduce trail possibly making the bike unstable. If you both reduce rake and reduce the offset in the triple clamps, it is possible to maintain a safe amount of trail and have the advantages of reduced rake (quicker handling).
- dutchz
Re: Factory rake
08 Jun 2007 12:04
What fossil said. Aditionally, I doubt deraking the chassis is really worth it. If you put some taller shocks in the back and put an 18" tire in the front, it will most likely drop the rake enough without making the bike really unstable. You can make additional small changes by dropping the forks in the trees and tire choice front and rear. Remember you need ground clearance too.
1974 Kawasaki Z1
Stock front hub and rear axle.
- Makarth
Re: Factory rake
08 Jun 2007 16:09
For more on how changing the rake effects your bike read this article about "caster"
www.ozebiz.com.au/racetech/theory/align.html
- Fossil
Re: Factory rake
08 Jun 2007 16:49
this might help...
www.performanceoiltechnology.com/rake_and_trail.htm
- dutchz
Re: Factory rake
08 Jun 2007 17:32
and this is a pretty cool calculator, plus a clear picture for reference
www.rbracing-rsr.com/rakeandtrail.html
1974 Kawasaki Z1
