New bars for 79 KZ750 twin?
  • KZ7501979
  • KZ7501979's Avatar Topic Author
07 Jun 2007 17:32
#147275
Good evening! I recently purchased a 750 twin and cant stand the stock bars on there. I bought a set of drag bars from ebay, but the controls do not fit properly on these bars (throttle and master cylinder want to run into the gages). The drag bars have almost no rise to them, so I am guessing this is my problem. I would like a set of bars with a more sporty look, but still somewhat comfortable. I did try a few searches, but couldn't find exactly what I was looking for.
Thanks!
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
Re: New bars for 79 KZ750 twin?
07 Jun 2007 18:23
#147288
I like the cheap "SuperBike" bars from RideNow Motorsports (f.k.a AZMotorsports.com) - got 'em on the first 750. They have a 2" rise, and are absolutely perfect.
Got the "Daytona" model for the second 750 for a slightly more stock look, but still only a 4" rise.
I have the "Euro" model on the rebuild 400, and I'm not too fond of the position; A bit too pulled back and downward for my wrists...
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • speedadict
  • speedadict's Avatar
07 Jun 2007 18:37
#147294
I would be more than happy to take some close up pictures of the drag bars installed on my 79 twin if it will help you.
  • KZ7501979
07 Jun 2007 18:55
#147299
That would be awesome. I couldnt for the life of me figure out how to mount everything to make it work.
Thanks for the other bar tips as well!
  • Voodoosoup
  • Voodoosoup's Avatar
07 Jun 2007 19:24
#147319
I had drag bars with a slight pull-back on my 650.
The master cylinder did slightly rub the gauges but I was able to fit everything on there.
  • speedadict
07 Jun 2007 19:31
#147322
My pics will have to wait till tommorow...
These are the bars I have,
cgi.ebay.com/ebaymotors/DRAG-BARS-MOTORC...dZ1QQsspagenameZWDVW
So if yours are at least 28" wide, they will work. More to come...
  • KZ7501979
07 Jun 2007 20:02
#147340
Those are the exact bars I bought. :)
  • speedadict
07 Jun 2007 21:16
#147358
Then you shall be in luck my friend. ;)
  • Biquetoast
08 Jun 2007 05:26
#147416
I have to say that even with the "Superbike" bars it's extremely tight.
I almost thought it wasn't going to work, and the brake line was severely cramped in around the headlight. I had to re-route it across around the other side of the back of the headlight as well, but then it all fit.
I eventually just replaced it with braided stainless steel. I would look at that bent old stock hose every time I had to do a hasty stop and cringe... ;)
...I didn't have that much trouble with throttle cables...oh and I ran the clutch cable down the other front chassis leg to take up some slack, but I'm sure the right thing to do is to get a shorter cable(s)...
kz750twins.com
  • steell
  • steell's Avatar
08 Jun 2007 06:08
#147428
When you figure out what cables work well with Superbike bars.
Be sure to let me know :)
  • speedadict
08 Jun 2007 20:14
#147675
Ok,
To install your drag bars, first understand it will not be a quick 10 minute project... In order to install them, the fit will be very tight, but it works with the stock brake line, and the stock length clutch cable. When I installed my bars, I had to loosen the nut at the top of the brake line,(at the master cylinder) and rotate it slightly upward. (I loosened mine only enough to rotate it, and did not even need to bleed the brake when I was finished) Keep it loose while your working with everything and tighten it up last. More difficult than the brake side of things was the clutch cable. Shortly after installing my bars my clutch cable snapped. I ordered a new one from Z1 enterprises. You need to take your time and be a little creative about how it is routed so that it works freely, and doesn't look stupid. The cable goes from the lever, to behind the speedo, around the headlight and down the right side frame tube. It crosses over at the bottom of the frame and into the engine case. Use some black zip ties to keep things looking nice, and keep the cables away from the hot pipes. I have not had any problems with this set up, and the look and feel is well worth the effort! Keep the faith, it will work if your patient! ;) When you get good at this, try going to clubman bars! What a pain they are!
  • speedadict
08 Jun 2007 20:17
#147676
Another...
