front master cylinder interchangeability
  • greatbeefalo
  • greatbeefalo's Avatar Topic Author
04 Jun 2007 12:11
#146213
Is it possible to swap out a later model Kawasaki front master cylinder for my old 1980 750? I need to replace the front master but I cant find a decently priced one anywhere. I was thinking maybe one of the later ZX models would work, unless im way off.
  • wireman
  • wireman's Avatar
Re: front master cylinder interchangeability
04 Jun 2007 12:21
#146216
sure;)
  • greatbeefalo
04 Jun 2007 13:24
#146231
any model suggestions? Or just find another 750 and call it good :P
  • StreetfighterKz
  • StreetfighterKz's Avatar
04 Jun 2007 13:30
#146232
I don't know if you have twin disks or not but I've used a ZX M/C when I swapped to dual disk a few years back. It worked out nice just make sure you match the M/C size to the calipers.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • conpewter
  • conpewter's Avatar
04 Jun 2007 13:50
#146236
Speaking only from reading on this forum about it, and owning a 1980 KZ750... I think that you can find another master cylinder that would work, it would need to be the same bore that your current one is (5/8 plunger?) because of the duel disks, also it will be a bit of a chore finding one that is going to set level on the stock handlebars.
Generally though if the conditions above are true, you can make it work (probably stick to Japanese bikes though)
I've read of several people switching to a lower handlebar and changing out the MC at that point.
  • JMKZHI
  • JMKZHI's Avatar
Re: .
05 Jun 2007 08:36 - 03 Dec 2008 10:42
#146502
del
Last edit: 03 Dec 2008 10:42 by JMKZHI.
  • daxx
  • daxx's Avatar
06 Jun 2007 19:50
#147030
just put on a 01 zrx 1200 master on my 78 kz1k with dual disc.
works mint!
  • daxx
  • daxx's Avatar
06 Jun 2007 19:50
#147031
works mint!
