Floorboards?
  • slickware
  • slickware's Avatar Topic Author
  • My bike is as old as I am
Floorboards?
31 May 2007 07:32
#145194
In the bottom of this photo, the crash bars are attached to a black metal bracket.
Can anyone tell if this is the same bracket that you would attach floorboards from a KZ1000-Police bike, to?
Thanks!
edit: this image attachment is HORRIBLE... the size constraint on linked images is SUCH A PAIN! Who uses "500" as a maximum size? Seriously!
Post edited by: slickware, at: 2007/05/31 10:34
1982 KZ1100 Spectre
Old. Shiny.
  • Zthou1977
  • Zthou1977's Avatar
Re: Floorboards?
13 Jul 2007 09:04
#156620
No, the floorboards on the KZ1000P-series are fitted to extra pieces of frame-tubing (diameter about 3/4 inch) that are welded to the lower frame tubes. See the attached picture:
1977 Z1000A1, 1982-1986 KZ1000P (built from two piles of parts), Moto Martin Z1200 (trying to get it registered), 1977 Z650B1
Utrecht, The Netherlands
  • KZPOLICEPARTS
  • KZPOLICEPARTS's Avatar
Re: Police Floorboards
25 Aug 2007 19:18
#166327
The KZ 900 and KZ 1000 Police bikes (up to 1981) had bolted on floor boards. The KZ 900 was different than the KZ 1000 floorboards. I would suggest using the KZ 1000 floor boards for other Kawasaki projects as I have found that they will bolt onto just about any Kaw 4 cyl from 1975 and up. I included a pic of a KZ 900 to hopefully show how they are bolted on. Good luck!
Pete
