FLAT: tube or no tube.
  • squints
  • squints's Avatar Topic Author
30 May 2007 19:29
#145048
I got a flat tire. I thought it was a tubed tire, but now am not so sure. Says right on the tire "Tubeless:on tube type rim fit tube". What does that mean???
I Filled it with an air compressor and air was hissing out from the rim lock nuts. Tried some of that fix a flat stuff with no success. Tire is a Dunlop Elite II with only about 4,000 miles on it.
Damn:S
traded my classic Kz's for a 2001 Kz1200r
Upstate NY
  • N0NB
  • N0NB's Avatar
  • Blue handles better
Re: FLAT: tube or no tube.
30 May 2007 19:48
#145056
Just what it says! ;)
On a rim designed for tube type tires, a tube must be installed. The tubeless tire will work in either situation, but a tube type tire will not.
I suspect you have a tube as the air is coming out between it and the tire and escaping through the rim locks.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel :D )
  • steell
  • steell's Avatar
30 May 2007 20:16
#145064
I have never seen a tubeless rim with rim locks, anyone else ever see one?
If your rim has rim locks, then it's a safe bet that it has a tube.
And you need a new one :)
  • BSKZ650
  • BSKZ650's Avatar
31 May 2007 05:36
#145162
which bike? if its a spoke wheel tube only, if its the mag type, it will say on the rim tubeless, but you can run a tube in it if you want
77 ltd1000, current rider
76 kz900, just waiting
  • mariozappa
  • mariozappa's Avatar
31 May 2007 06:11
#145169
+1 on what Steell said.
If you have rim locks, there's a tube in there. That's what they are for.
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • AR15Ron
  • AR15Ron's Avatar
31 May 2007 06:27
#145175
I just went through that myself. Was leaking around the nuts holding the valve stem to the rim. Turns out there was a tube in there even though my tires said tubeless. Of course they didnt have any tires in stock and neither did anyone else I called so I had to have a new tube put into my crappy old tire, cost me about $55. On the plus side he didnt put a scratch in my Lester Mag :)
Ron
