Belt Alignment
  • Tyler
  • Tyler's Avatar Topic Author
Belt Alignment
30 May 2007 18:05
#145016
I am having trouble getting the belt to track straight on my 440. If I adjust the back wheel so the alignment marks are even the belt pulls to the outside of the pulley and squeaks when I rotate the tire by hand. When I get the belt to track straight the rear wheel is clearly out of alignment. So is there a easy way to get this right? Do I have to shim the drive pulley to align the belt? Unless the rear wheel is askew to the centerline of the bike the belt pulls ot the outside.
"74 Yamaha DT 400 Enduro
  • wireman
  • wireman's Avatar
Re: Belt Alignment
30 May 2007 18:44
#145031
check your swingarm bearings for slop that could be letting things out of square.i dont trust the stock adjustment marks,use a straight line to align wheels;)
  • Tyler
Re: Belt Alignment
31 May 2007 08:00
#145200
Already checked that out, the swing arm is like new.
  • hwms
  • hwms's Avatar
Re: Belt Alignment
31 May 2007 10:00
#145222
If it has axle spacers check out. sounds like wheel is spaced too far to right.
  • Tyler
Re: Belt Alignment
31 May 2007 11:17
#145238
I was kinda thinking the same thing. So what is the best way to correct that? Machine the right side spacer down and put a washer on the left?
  • hwms
  • hwms's Avatar
Re: Belt Alignment
31 May 2007 12:56
#145266
I would determine which way the wheel may be out of line, IE: right or left (facing toward front of bike) and then reduce the space. As I said, it would appear that the wheel may be too far to the right. If so, reduce the space on the left and add to the space on the right.
Make sure that the drive pully is all the way on the output shaft.
Post edited by: hwms, at: 2007/05/31 15:57
