fork oil change
  • Booncha57
  • Booncha57's Avatar Topic Author
fork oil change
28 May 2007 13:22
#144287
im going down to deal's gap tomorrow and i wanted to change my fork oil today before i left. it looks like somebody before me had a hard time taking off the fork caps, they are a little chewed. i got the front wheel off the ground and now i cant get these caps to budge. the metal seems very soft and i dont want to mess them up. do i have to take the forks off to do this job or am i doing something wrong?
Re: fork oil change
28 May 2007 14:18
#144302
Hoping the very fine threaded fork caps were not cross-threaded when last installed by Godzilla. :(
It is usually the soft male threads on the cap that get stripped, and not the female threads inside the steel fork tubes. If stripped, should replace the caps.
If dry ice is available, could "freeze" the cap before immediately attempting to unscrew. (Regular ice with salt might work but not be as cold).
Hope others may have better suggestions, but if brute force, pipe wrench, and all else fails, may require carefully hack-sawing caps vertically through the middle (use vacuum cleaner to constantly suck away filings and keep filings from falling inside the fork tube). Or some other destructive
method while avoiding damage to fork tubes.
Do not use any type of sealer or locking agent when re-installing the caps. The fine threads are designed to prevent leakage. It is sometimes difficult to get the cap started just right when beginning to screw it onto the fork tube. Especially where the spring must be compressed while starting the thread. Just be very careful and go slowly and deliberately. This is the maneuver where cap threads are often stripped from being improperly started.
Good luck! :)
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: fork oil change
28 May 2007 16:43
#144337
Did you loosen the top tripple clamp bolts first? Otherwise they could be near impossable to get out. :pinch:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • vrdw
  • vrdw's Avatar
Re: fork oil change
28 May 2007 17:31
#144349
I'm looking for fork tubes (stantions) to replace the pitted ones on my 1981 KZ1000J. The Js measure 38mm, can I use GPZ1100 fork tubes? or are they 37mm? any suggestions welcome.
VRDW, Canada
