Rear tire rub...
- vach
Rear tire rub...
28 May 2007 12:34
I just noticed this when I went to Indiana to work on my bike.. It's been parked for 8 years and I'm just figuring out some of the stuff I did to it. I put a new 130/90 on the back and I see that I guess at times it is rubbing agianst the arm that comes off of the rear brake.. Is there anty work around for that? Happy Memorial Day my peeps..
1979 kz650 B. Chicago, Illinois
- Fossil
Re: Rear tire rub...
28 May 2007 14:50
Not being familiar with your model, but I think if it is a tubular brake stay, you could replace it with one made from flat steel 1" wide, 1/8" thick. If it is a flat piece of steel, can you space it out just enough to clear the tire?
- vach
28 May 2007 14:53
Ok, yes the one on my bike is flat. I will put a spacer on, I'm sure that will cut it thanks for the advice..
- wireman
28 May 2007 20:58
Fossil wrote:
1/8" isnt much meat to keep that caliper from spinning if you need to lock em up;)Not being familiar with your model, but I think if it is a tubular brake stay, you could replace it with one made from flat steel 1" wide, 1/8" thick. If it is a flat piece of steel, can you space it out just enough to clear the tire?
- anarki650
28 May 2007 21:08
B model 650 is a rear drum brake. I was able to just bend the metal rod on mine just a touch when I put a 130/90 tire on and I haven't had it rub yet.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Omaha NE
- wireman
28 May 2007 23:25
drum brake arm is under tension so it gets by with small brake arm.disc brake caliper is mounted on top putting bar under a compression load which requires bigger arm;)
- Fossil
29 May 2007 01:33
wireman wrote:
Good point - you're right, it isn't much if it's under compression.
Fossil wrote:1/8" isnt much meat to keep that caliper from spinning if you need to lock em up;)Not being familiar with your model, but I think if it is a tubular brake stay, you could replace it with one made from flat steel 1" wide, 1/8" thick. If it is a flat piece of steel, can you space it out just enough to clear the tire?
- BSKZ650
29 May 2007 07:32
are you sure you have the tire square in the swing arm? mine is close but you have to make sure the wheel is centerd
77 ltd1000, current rider
76 kz900, just waiting
