Upper Shock Mounts for a GS swingarm conversion
  • aacoop
  • aacoop's Avatar Topic Author
26 May 2007 21:51
#143845
I am doing a GS swingarm conversion on a 79 MKII and I also have the 83 GS 11 clevis type shocks.
I am interested to know how guys are converting the upper shock mount to suit the Suzuki clevis type shocks on the KZ frame. The KZ upper stud is bigger 14 mm OD and the suzuki shocks bushings are 12 mm ID.
I was thinking of cutting the stock shock bolt off and
drilling for a 12 mm bolt..
The shocks are mint and I dont want to wreck the bushings and rubbers.
Ideas?
  • donthekawguy
  • donthekawguy's Avatar
Re: Upper Shock Mounts for a GS swingarm conversion
26 May 2007 22:15
#143853
You might be ablt to fit the bushings from your kz shocks into the gs shocks. I never got that far on mine. :P
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • smithgpz
  • smithgpz's Avatar
27 May 2007 07:36
#143906
you get the right shocks and leave the frame the way it is.;)
  • wireman
  • wireman's Avatar
27 May 2007 11:03
#143955
change shock bushings;)
