Sprocket recommendation 82 GPZ
  • solitary
  • solitary's Avatar Topic Author
24 May 2007 12:37
#143146
I have an 82 GPZ, it has 24,000 miles on it, the chain/sprockets have seen better days.
So it's time for a new one.
I have no idea what is on it now, but factory is 16 front 38 rear as far as I know.
I do mostly highway 84 miles round trip on my daily drive to/from work. About 10 miles/day is city.
Should I stick with the factory (or what ever is on there now) or would you recommend something different?
Occasionally I'll take it out on the windiest road I can find for some fun, but mostly it's cheap enjoyable transportation.
Also, to confirm that I'm not being overly cautious, is there a way to check the chain's wear without taking it off the bike? I know the method is to hand a weight on it and measure the distance between a given number of links, but is there another way?
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Sprocket recommendation 82 GPZ
24 May 2007 14:13
#143167
I'm guessing you have a GPz550 (based on the # of sprocket teeth)...my inclination is to keep the # of teeth at factory recommendations...those Kawasaki engineers were pretty clever and it sounds like you do several types of riding. If you think the chain is worn, then replace it, don't worry about specs as it will generally break at the worst possible time...when you replace the chain, make sure you also do the sprockets, and vice versa. :)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • solitary
25 May 2007 06:43
#143361
Oops! yes it is a 550.
Stock specs it is.
I'm thinking my best bet is JT sprockets:
Front :
Rear
Chain is looking like an eBay deal .
Anyone got better ideas?
This is a *simple* installation as far as I can tell, remove the rear wheel, remove the rear sprocket using the allen-head bolts, replace, re-install the rear wheel w/o the chain.
Remove the front sprocket cover, chain, remove the sprocket (I'm assuming it's bolted on?), replace.
Then install the chain and tension it.
Anything I should be aware of? Should I use a rubber mallet for installing the rear wheel bolt or will it slide in easily? I don't have a dead blow hammer since I rarely need one.
Anything I'm forgetting?
  • OKC_Kent
  • OKC_Kent's Avatar
25 May 2007 07:43
#143365
It may be best to keep everything together and start off by getting the countershaft nut off first; then remove the chain and wheel. It's the easiest way to remove the front sprocket. Have a friend step on the rear brake pedal as you loosen the front nut.
I just replaced the sprockets and chain and had to have my son stand on the rear brake pedal to lock the system up, while his friend pushed on a 6ft pipe attached to the breaker bar as I heated the countershaft nut to a dull red with a torch.
It was fun.
NEVER use red loctite on the shaft threads (as I did 2 years ago) or you will need a pipe and two friends to get the sprocket off in a couple years.
Cashion, OK
78 KZ650 B2 85,000+ miles
  • solitary
25 May 2007 07:57
#143367
Forgive my stupidty.
The countershaft bolt is the 3/4" diameter bolt that runs through the rear wheel?
I loosened that last year when I adjusted the chain, no problem, but I didn't take it the whole way off. Or is this not the bolt your're talking about?
Do you know what the torque spec is?
  • mariozappa
  • mariozappa's Avatar
25 May 2007 08:05
#143369
No, the countershaft is where the front sprocket is.
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • solitary
25 May 2007 08:08
#143371
Ah, thanks for the warning.
I hope I don't have to put a torch to that.
  • OKC_Kent
  • OKC_Kent's Avatar
25 May 2007 08:38
#143381
The countershaft nut is big, on my bike it's 1-1/16" or something like 27mm. Check yours now before the parts get here so you have time to run out to the store and buy one.
Cashion, OK
  • solitary
25 May 2007 10:35
#143424
That would figure too. I have a 26mm socket, a 28mm socket and even a 29mm socket. No 27.
I'll pull the cover off and check.
I've also got a 1 1/2" socket that I tried to get a water heater element off with. Using a 3' pipe, I had that 18" breaker bar bent like a banana and it wouldn't move. Didn't try torching it because it was installed in a "closet" and thought replacing the water heater would be cheaper than replacing all my stuff after the house caught fire.
  • steell
  • steell's Avatar
25 May 2007 17:36
#143505
Doesn't the GPz550 have the countershaft sprocket held on by a lockplate that is retained by two bolts?
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
25 May 2007 18:03
#143514
Yep that is the setup on the 550's lockplate held on with 2 6mm bolts. Piece of cake to change.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
  • OKC_Kent
  • OKC_Kent's Avatar
25 May 2007 19:49
#143541
I didn't know that this sprocket was bolted up like that! Learn something new today.:)
Cashion, OK
