forks size
  • gremlin497
  • gremlin497's Avatar Topic Author
forks size
23 May 2007 14:22
#142857
how can you tell what size forks are on bike. have 1977 kz1000a and guy has rim i want but he asked if i had the smaller or large size forks on my bike. how can you measure them
1977 KZ 1075 (FBG), 29 Smoothbores V&H Mega
  • wireman
  • wireman's Avatar
Re: forks size
23 May 2007 16:31
#142891
they are same diameter from 73-80 as far as i know around 36mm;)
  • Muddy
  • Muddy's Avatar
Re: forks size
23 May 2007 19:17
#142935
That was me you talked to on the rim. I just saw your post, hope you see this. Its the axle size not the forks. The wheel uses the smaller diameter axle found on leading axle forks.
I also have a sopke rim in the same size/configuration. Let me know if you can use it if for some reason you don't get the one on ebay.
Post edited by: Muddy, at: 2007/05/23 22:18
