Fix-a-flat
  • violentvintagecycles
  • violentvintagecycles's Avatar Topic Author
Fix-a-flat
22 May 2007 09:49
#142415
ok, whats everyones feeling on this stuff? I remember using it as a kid with alot of success but against popular opinion. Actually never did me wrong, but i dunno about the next guy when he took the tire off. I noticed there is new stuff called SLIME. ANyone use this, ok, or what? Thinking this is essential stuff to have on a long ride, no?
  • flht1997
  • flht1997's Avatar
Re: Fix-a-flat
22 May 2007 09:54
#142419
I would not use it on a bike unless it is a real emergency. it does not seem to work real well with innertubes either. I have tried it in the past when i was in a sticky situation, ie: 1200 miles from home with a flat rear tire, but it did not work. when i go on trips now i carry a patch/plug kit and an air compressor.
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
  • RonKZ650
  • RonKZ650's Avatar
Re: Fix-a-flat
22 May 2007 10:03
#142420
Same exact experience here. Normally won't seal a tube and if it does it wont last long. Sometimes comes in handy though if you have a "very" small leak and need some air to get you to the next town.
  • riverroad
  • riverroad's Avatar
  • 1980 1000LTD B4
Re: Fix-a-flat
22 May 2007 10:14
#142426
I've used the "Slime" on my lawn tractor, but I haven't put it in by bike tires. So I don't know how well the stuff balances out at bike speeds. But I used to get flats almost everytime I cut my grass because of dogwood thorns. But it's been a couple years since I put the stuff into my lawn tractor tires and I haven't had a flat since. I haven't even added any air to them since.
  • BSKZ650
  • BSKZ650's Avatar
Re: Fix-a-flat
22 May 2007 11:14
#142451
if you dig around you will find slime for tubes, although most places only have the stuff for tuble less.
I used it in tube tires on a rented bobcat and it worked ok, got thru the job and I couldnt tell you how many holes were in the tires when we got done, but it was a lot.
I would only use it in an emergency on a bike, thorws the tire out of balance, but it will get you home
77 ltd1000, current rider
76 kz900, just waiting
  • tw..
  • tw..'s Avatar
Re: Fix-a-flat
23 May 2007 06:57
#142720
I've use slime with success in a tubeless tire for an entire summer although I don't recommend using it that long. I had a nail in my rear tire and was to lazy and cheap to change it. I will agree that the slime will throw you tire out of balance. I had a slight vibration in the rear end the went away when I installed the new tire.
2-1976 KZ900 A4
1995 KZ1000 Police bike
1978 Z1R
  • loudhvx
  • loudhvx's Avatar
Re: Fix-a-flat
28 May 2007 13:02
#144281
For tubeless tires, I always paid the extra to get it patched from the inside, but with so much construction debris in the alley, I'm getting sick of al the flats.
I bought this:
www2.northerntool.com/product-1/200323217.htm
I was not a big fan of the plug method, but this seems to be a very good type of plug. I'm going to try it in the next week or so.
  • neilage66
  • neilage66's Avatar
Re: Fix-a-flat
28 May 2007 15:50
#144327
I've plugged alot of automotive tires the old fashioned way, but I like the idea of the brass tips on the plugs...cool tool Lou. B)
  • BSKZ650
  • BSKZ650's Avatar
Re: Fix-a-flat
29 May 2007 07:30
#144502
maybe its me, but once I get a flat on a bike, I am replacing the tube no matter what, and tubeless I would have to think real hard about a plug, unless it was a get me home and change the tire situation
