Has anyone bought one of these master cylinders???
- Mcdroid
- Gone Kwackers
Re: Has anyone bought one of these master cylinders???
22 May 2007 09:54
Richard:
Just followed the Shindy link and liked what I saw...but what I didn't see was any prices:) So, just how scary can Shindy prices be?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
22 May 2007 10:06
OKC_Kent wrote:
What about this one?: www.z1enterprises.com/detail.aspx?ID=33
Post edited by: Skyman, at: 2007/05/22 13:09
Nope. That kit is for the B1 model, which has a round master cylinder.. If you have a true 78 B2 model, and it seems you do because the cylinder you show is trapezoid, that kit from Z1 won't work.
West Linn, OR
- JMKZHI
Last edit: 03 Dec 2008 10:55 by JMKZHI.
- OKC_Kent
22 May 2007 11:16
Skyman wrote:
That says it is for the 5/8" cylinder. If you look on the bottom of your master cylinder, at least on mine, is the number "14" cast into it. I think that implies our trapezoid cylinder is 14mm, single disk. A 5/8" cylinder is just a hair under 16mm.
OKC_Kent wrote:Nope. That kit is for the B1 model, which has a round master cylinder.. If you have a true 78 B2 model, and it seems you do because the cylinder you show is trapezoid, that kit from Z1 won't work.
What about this one?: www.z1enterprises.com/detail.aspx?ID=33 <br><br>Post edited by: Skyman, at: 2007/05/22 13:09
Cashion, OK
78 KZ650 B2 85,000+ miles
- GPz750KS
22 May 2007 11:30
Mcdroid wrote:
About $150.00 for what I have. The radials are much higher. They are sold thru parts-unlimited. You can get pricing thru their online catalog. Nice thing about the Shindy or magura, rebuild kits and parts are available. The Ebay one I didn't see anything listing replacement parts or could I find an exact manufacturer.
Richard Z.
Post edited by: GPz750KS, at: 2007/05/22 14:33
Richard:
Richard Z.
- Skyman
22 May 2007 11:44
OKC_Kent wrote:
Oops. My bad. I saw "'78 B2" and I was thinking KZ1000, like mine. When I saw you mention "single disk", I knew we were talking apples and oranges. Sorry.
Skyman wrote:OKC_Kent wrote:Nope. That kit is for the B1 model, which has a round master cylinder.. If you have a true 78 B2 model, and it seems you do because the cylinder you show is trapezoid, that kit from Z1 won't work.
West Linn, OR
- tommyp76
22 May 2007 12:14
OKC_Kent wrote:
Mine has 5/8 stamped on it. God only knows what all the parts on this bike are from. She was in pretty bad shape when I got her. The brakes are really the only think I have left to do before I put her on the road.
1978 KZ650B
22 May 2007 15:04
Regarding 14mm trapazoidal master cylinder piston ---
Trapazoidal front master cylinder was introduced in 1978 on single front disc KZ1000-A2. It was the only year for the 14mm, and was increased to 5/8" in 1979 (KZ1000-A3) and thereafter for use with the dual front disc models.
The 14mm piston size does not appear on my local dealer's microfish and his best guess order as shown resulted in a 5/8" piston way too large to fit. Thanks to Jeff at Z1E who furnished the correct part number for the 14mm piston, which I obtained last year through the dealer. Don't have the Kaw part # handy, but will be glad to post it if needed.
The trapazoidal 14mm items are available at Redline
Redline
Here's the hard to find o-ring seal between reservoir and base
o-ring
If needed, here are the rubber diaphram and other reservoir items (which I believe are common to both 14mm and 5/8" sizes)
diaphram
And here is the elusive 14mm piston (last year's priced was par with dealer)
14mm m/c piston
Happy Wrenching!
Post edited by: Patton, at: 2007/05/22 19:29
Post edited by: Patton, at: 2007/05/22 23:09
Redline
o-ring
diaphram
14mm m/c piston
Happy Wrenching!
- Voodoosoup
22 May 2007 16:06
Mine just arrived today. It's for the ex500 front end that I'm putting on my bike.
Looks decent for the price. This one was only 29.99 + shipping.
Post edited by: Voodoosoup, at: 2007/05/22 19:08
- OKC_Kent
22 May 2007 19:33
tommyp76 wrote:
I thought the trapezoid style was only 14mm. I really don't know what to tell you now. I would pull it apart, clean it, and compare it to the pictures on the Redline page we posted. If the bore is 5/8" you should have no problem using it with dual discs.
OKC_Kent wrote:Skyman wrote:OKC_Kent wrote:Nope. That kit is for the B1 model, which has a round master cylinder.. If you have a true 78 B2 model, and it seems you do because the cylinder you show is trapezoid, that kit from Z1 won't work.
Cashion, OK
