Help, need fork seal info...
- JMKZHI
Last edit: 03 Dec 2008 10:51 by JMKZHI.
- kzluke750
Re: Help, need fork seal info...
19 May 2007 20:21
On my 80 750 the cap unscrews using a a wrench on the schader valve housing. Theres two flat sides around where the valve goes into the cap. Hope this helps.
1980 750 LTD Stock
Motors run on electricity, engines run on fuel.
-Jerry Baxter
-Jerry Baxter
- Tyler
20 May 2007 16:10
"74 Yamaha DT 400 Enduro
- Tyler
21 May 2007 23:45
Weird. I can turn the shrader valve with a socket but the upper cap has no threads, it just spins.
I decided to put it all back together. I put the new seals in (thanks Z1), dressed the upppuer tubes with 800 grit and meatal polish, and bolted the tubes back together. I used a Hobico model airplane fuel pump to fill the tubes with about 155 cc of 15w though the drian plug. I laid them down on my workbench and cranked away with the hand pump.
SO I CHEATED...SUE ME!!!
I got her back together and went for a quick ride. Got back and found no leaks and the same air pressure I filled 'em with.
Still I have no idea how those tubes come apart.
- JMKZHI
Last edit: 03 Dec 2008 10:52 by JMKZHI.
