kz400-440 wheels fit kz650?
  • bkitchen
  • bkitchen's Avatar Topic Author
22 Dec 2005 08:41
#14061
There is a set of wheels on ebay and was wondering if a det of wheels off of a kz400-440 would fit a kz650. Both have rear drums.
  • JMKZHI
  • JMKZHI's Avatar
Re: .
22 Dec 2005 09:14 - 03 Dec 2008 20:09
#14064
del
Last edit: 03 Dec 2008 20:09 by JMKZHI.
  • mykznme
  • mykznme's Avatar
Re: kz400-440 wheels fit kz650?
22 Dec 2005 13:34
#14101
i just had a similar problem
Re:will a 78 kz400 front end fit on my 76? - 2005/12/22 16:27
well ive talked to a freind that has expeirience rebuilding kz's and he said the axles are a different circumference.
so basically id either have to buy a 78 rim to go with the forks or put the axle on a lathe.
apparantly kawasaki was eperamenting with axles sizes
seems to me they thought the kz400 axles could use a lil beefin up.
if the wheels are newer then 76 they might work
R.I.P. Odd Ivar
