Fork Diameter ...
- badboie
- Mcdroid
- Gone Kwackers
Re: Fork Diameter ...
15 May 2007 23:25
Well, on a 750(4) it is 37mm but I haven't a notion on a 750(2). Which do you have?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- badboie
- JMKZHI
Last edit: 03 Dec 2008 10:58 by JMKZHI.
- duncan
16 May 2007 09:06
i was just doing a search yesterday on fork diameters. one of the posts said that all the specs are on the Z1enterprises site......looks like it's 36mm
- Mcdroid
- Gone Kwackers
16 May 2007 10:06
JMKZHI wrote:
Mine (KZ750R1) measures at 37mm:)
36mm? JMK.
Edit: I just measured the upper fork tube from an 82 750-Ltd-4 - it's 36mm.<br><br>Post edited by: JMKZHI, at: 2007/05/16 12:26
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- mariozappa
16 May 2007 10:11
Hmmmm...
My 82 750 H3 has 36mm forks, but they are not the originals.
I wonder if 37mm would fit without changing the triple tree?
McDroid, not to hijack this thread but could you mesaure the inside distance between the upper fork legs. Enquiring minds want to know.
1977 KZ650C1
and the KZ650/KZ750 Conversion
- Mcdroid
- Gone Kwackers
16 May 2007 10:51
mariozappa wrote:
Absolutely. I'll post tonight, after I get home to my scooters:)
Hmmmm...
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Mcdroid
- Gone Kwackers
17 May 2007 03:20
mariozappa:
I may have been a bit hasty with my original measurements...last night, I took my time, used a vernier caliper, and repeatedly got 36.6mm as a fork diameter...so, you tell me...do I have 36mm or 37mm forks:unsure: ? But, I digress, the measurement you asked for was 150mm...and yeah, I measured it correctly:laugh:
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- mariozappa
17 May 2007 05:28
Thanks McDroid.
I have a sheet (somewhere) at home from an out of business supplier for Kawasaki forks.
It shows what size forks for different models that they used to sell. Alot of them were 36mm, and they went on 650's, 750, and some 1000's.
I would not doubt that it would measure 36.something
If I can find the sheet this weekend I will try to post the information.
Thanks!
Thanks!
1977 KZ650C1
- steell
17 May 2007 06:15
83-85 GPz750 had 37mm forks, KZ750 had 36mm forks, I'm not sure about the 82 GPz750.
750 twins from 76-80 had 36mm forks, as did the 650's and 1000's.
At one time I had the following, GPz550 forks 35mm, KZ750B and G 36mm, KZ650SR 36mm, GPz750A1 37mm, and KZ1000M2 38mm.
