How much cushion does tank need on the backbone?
  • Muddy
  • Muddy's Avatar Topic Author
14 May 2007 08:19
#139873
I'm switching tanks to a benelli knock off for my cafe project. If I leave the rubber cushions on the frame backbone the tank sits way to high, if I take them off and the tank sits right on the frame its way better, and I can work with it. I know that resting the tank right on the rails of the backbone is most likely a bad idea, but how much cushion do I actually need?
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: How much cushion does tank need on the backbone?
14 May 2007 08:55
#139880
I wouldn't think you need a whole lot of cushion. Try taking an old inner tube and cutting some small strips from and it. Electrical tape the strips around the frame back bone and see how it looks. I think the cushions are there mostly to protect the paint on the frame/tank. The strips should give you the protection without more than 1/16"-1/8" of height.
Let me know if that works.
later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • pstrbrc
  • pstrbrc's Avatar
  • '81 GPz 1100 project
14 May 2007 09:07
#139884
Actually, the most important function the isolators perform is making sure that whatever movement between the frame and tank does not wear a hole in the gas tank, and that whatever vibration the frame experiences, the vibrations do not make it to the tank with the magnitute that would cause weld failure of the tank. Remember, it's a GAS tank. Not the kind of thing you want to experience failure on.
At the very least, reinforced coolant hose 1 1/2 inch dia, split and forced over the frame.
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
14 May 2007 10:02
#139903
If room enough, maybe a section of old foam rubber handlebar grip sliced down the side and fitted over the frame rail. :)
  • OKC_Kent
  • OKC_Kent's Avatar
14 May 2007 10:44
#139911
Or maybe some foam pipe insulation from home depot.
Cashion, OK
78 KZ650 B2 85,000+ miles
  • Muddy
14 May 2007 10:58
#139912
Thanks,
Foam pipe cushion and collant hose are great solutions.
  • OKC_Kent
  • OKC_Kent's Avatar
14 May 2007 11:16
#139913
Muddy wrote:
Thanks,
Might be better to keep metal coolant hoses away from contacting the foam and tank; how about zip ties, or as someone else suggested, electrical tape?
Cashion, OK
  • pstrbrc
  • pstrbrc's Avatar
14 May 2007 11:24
#139916
The advantage to coolant hose is the fabric reinforcement in it. Won't wear through as fast.
Elkhart, Kansas USA
14 May 2007 11:51
#139924
And also perhaps better tolerate the heat.
  • 77KZ650
  • 77KZ650's Avatar
14 May 2007 13:07
#139946
what about silicone? put a thin smear over the backbone, let it dry and try it. although i like the innertube and tape idea aswell
07 MDP Rookie of the Year
  • wireman
  • wireman's Avatar
14 May 2007 13:10
#139948
thats what i was gonna say!:P find some fore 1" pipe,it should fit fairly close;)
  • ronjones
  • ronjones's Avatar
14 May 2007 15:51
#139983
I used truck bed spray liner along the spine and under the tank. Still using the mounts but I think it has helped some of the vibration squeeks. Probably if you are resting the entire tank on the spine you will need something more substantial like what has been, already, suggested.
