unusual braking issue
  • Shaolinwind
  • Shaolinwind's Avatar Topic Author
08 May 2007 18:04
#138354
The front brake on my 1982 Kawasaki 750 CSR M1 is doing something unusual. In fact, a mechanic of 30+ years says he's never seen this before. If I am too gentle when pulling the brake lever, it softly pulls in to the hand grip and doesn't apply the brake. If I tug just a little more firmly, it works just like a normal brake.. What's going on here?
Post edited by: Shaolinwind, at: 2007/05/08 21:05
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
Re: unusual braking issue
08 May 2007 18:11
#138355
Master cylinder needs a rebuild,or You need to bleed the whole brake system.B)
1977 KZ1000 A-1
  • wireman
  • wireman's Avatar
08 May 2007 18:13
#138356
what sandy said;)
  • pstrbrc
  • pstrbrc's Avatar
  • '81 GPz 1100 project
08 May 2007 19:03
#138371
Hmmm...
Not sure I'd trust a mechanic who'd never seen that before. Your master cylinder seal leaks just a little. So when you pull hard, it doesn't leak as much as your piston travel displaces, so you have hydraulic pressure going to your brake cylinder. But when you pull lightly, you're only asking the piston to displace as much hydraulic fluid as your leaking seal allows to pass. No extra pressure for the brake. The warning for you is this: you're just one good hard squeeze away from your master cylinder seal completely giving up, and then it won't matter how much you squeeze, there won't be any brake. Get it rebuilt NOW. Your bike has given you all the warning you will get.
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
08 May 2007 21:39
#138424
pstrbrc wrote:
Hmmm...
EXACTLY!;)
I thought about that too,after I re-read the post a while later...what Mechanic wouldn't recognize those symptoms??:huh:
1977 KZ1000 A-1
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
08 May 2007 22:44
#138431
Dont dodle on this 1 pal.This is not safe.Please be carefull.
Post edited by: mark1122, at: 2007/05/09 01:45
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
