1980 Z1R Fork Swap
  • 1shooter
  • 1shooter's Avatar Topic Author
1980 Z1R Fork Swap
08 May 2007 07:13
#138130
Hello to any of you Kawasaki Guru's. I want to put modern upside down forks on my Z1R without modifying the frame, can this be done. What year and model of forks can I use? I also want to lower the bike a bit in the process. Thanks
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: 1980 Z1R Fork Swap
08 May 2007 08:46
#138166
Shooter,
Looks like you found your way over here. Congrats.
I know that Solomrus, Fossil, and quite a few others have done this swap. I don't remember if I told you, before at DB, but the frame shouldn't require any mods except maybe new fork stops (but you could always modify the new triple trees for this). Pretty much any USD except older 1100 Gixxer will lower your from end anywhere from 1-4 inches. Remember that just by switching from a 18-19" from rim to a 17" front rim will drop the front end too.
Post pics when you have them.
Later, Doug
Post edited by: StreetfighterKz, at: 2007/05/08 11:47
Post edited by: StreetfighterKz, at: 2007/05/08 11:49
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • Fossil
  • Fossil's Avatar
08 May 2007 14:13
#138283
I installed a '96 GSXR750 USD front end on my bike but I had to cut the fork lock off the frame to clear the ignition switch and cut down the fork stop to work with the Suzuki triple clamp. I am using the stock GPz tapered bearings with a modified KZ1100 stem pressed into the GSXR lower triple clamp. The front end and 17" wheel dropped the front 3".
Apparently the ZX front ends are an easier swap as far as the stem goes but I don't know about the fork stops.
Do a search, there's been a lot of info and different ways to do this.
  • wireman
  • wireman's Avatar
08 May 2007 18:30
#138360
but its a z1r!!!!!!!!!!!!!!!!!!!!!!!!!:ohmy: :ohmy: :ohmy: :ohmy: :ohmy: :ohmy: :ohmy: :ohmy: :ohmy: :ohmy: :ohmy: :ohmy: sorry guys i just like z1rs,its the ronkz650 coming out in me!:blink: :P oh yeah,welcome to z-jungle!(tm)B)
  • 1shooter
10 May 2007 07:02
#138845
Thanks for the info guy's. On the ZZR swingarm you installed, did you go with a mono shock, or conventional 2 shocks? Was the swingarm, bolt on, NO MODS? What year ZX forks would be my best choice? Any way of getting some pictures of your bike? I'd really like to start ordering parts to get this project started. Thanks again
