kz700 front brakes
- kz700rider
kz700 front brakes
06 May 2007 12:54
On the kz700 the brakes are not stopping me like they should. The lever still seems a bit squishy even after a bleed the lines.stamped on the side of the rotors it says MIN TH 4.5 MM. Both rotors measure at 4.7 MM.Obviously close to the mininum thickness.
Do I need new rotors?
Is the master cylinder going?
Any help would be greatly appricated.
Thanks
Post edited by: kz700rider, at: 2007/05/06 17:41
Thanks
- wireman
Re: kz700 front brakes
06 May 2007 16:13
have you tried flushing brake fluid or checking brake pads?
- OKC_Kent
06 May 2007 18:04
If you have bled the lines already then strap the brake lever tight to the grip with a bungee cord. This will allow any air still in the lines up and out into the master. Let this sit overnight and in the morning the lever should be firm. If it's not then maybe your hoses are just old and getting soft.
Cashion, OK
78 KZ650 B2 85,000+ miles
- steell
06 May 2007 18:06
More than likely you still have air in the lines, it takes a llllllllllloooooooooonnnnnnnnnnggggggggggggggg time to bleed KZ brakes manually, like a couple of hours or so for the front brakes.
A vacuum brake bleeder (less than $20 at Harbor Freight) makes it a lot faster and easier.
- kz700rider
07 May 2007 08:23
The pads are still there. Ill try straping the lever down overnight and checking the hoses.
What about the rotors? Although they are close to the mininum thickness , should I replace them ?
- Sandy
- Fly High,Tony
07 May 2007 08:34
I don't think You have to worry about the rotors.As long as they're within the limits,and they're not warped.
I had to unbolt My calipers from the bike,and hang them in a different position to get them to bleed properly.I know Others have had to do this as well.
I spent DAYS trying to get Mine to bleed out all the way,but in the end,the only way WAS to hang them at a different angle to get the last bit of air out.
There's a small pocket in there that won't bleed when they are mounted to the forks.
I just inserted a piece of plywood into each caliper,between each set of pads(dual front brakes)and went at it from there...and it DID eventually work.
1977 KZ1000 A-1
