Rear wheel swap 79 kz650
- vach
05 May 2007 13:53
Will a rear spoked with disc brakes from a Kz900 or 1000 fit my 79 KZ650 as a direct bolt on, no mods. If so, what years? I want a spoked disc setup that I can just bolt on. I have the rear master and caliper, I just need the rim.. Also, I noticed there is a cross reference program from kawasaki for the computer? Is this true? Where can I get it? Will it run on a mac? Most likely not but what the hell.....
Post edited by: vach, at: 2007/05/05 16:58
1979 kz650 B. Chicago, Illinois
- steell
Re: Rear wheel swap 79 kz650
05 May 2007 14:11
Nope, nothing will bolt straight on but a 650 wheel.
Cross referencing part numbers is easy, just go to Kawasaki.com put your cursor on "Owner info" and then click on "Parts diagrams", it pretty self explanatory after that.
- SLEEPER650
21 May 2007 18:22
STEEL I HAVE A 80 KZ750 I AM PARTING OUT. IM IN MICHIGAN WHAT PARTS ARE YOU LOOKING FOR?
78 650sr my baby
78 650sr waiting for rebuild
82 kz1100
82 kz1100
- vach
21 May 2007 18:48
Do you have a spoked rear wheel with a disc? The dual front discs? The have to be 4 bolt setup on the front. I'm not sure they will fit but I will ask... Thanks
Post edited by: vach, at: 2007/05/21 21:48
- gorack
23 Aug 2007 23:57
a kz 750 twin rear wheel should work remember you have to fabricate a mount for the rear brake resevoir im doing the same thing on my 77 650 what a pain in the azz
- gorack
24 Aug 2007 00:00
for the front you just need to remove chrome cover on right side of wheel its already threaded for another disc then you just have to get another caliper and a dual output brakesplitter
- steell
24 Aug 2007 05:30
gorack wrote:
Nope, the 750B twin rear wheel is not a direct bolt on to the 650, the 750B uses a 20mm rear axle just like the 1000.
