rear brake woow's
  • oldkaws4ever
  • oldkaws4ever's Avatar Topic Author
  • Have no regrets...... You only live once.
rear brake woow's
28 Apr 2007 00:49
#134925
i hope somebody here can help me, i have a 1976 kz 400d and the brake is frozen in place, and it wont move or budge. does anybody have any pointers or tricks i could try? thanks
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • steell
  • steell's Avatar
Re: rear brake woow's
28 Apr 2007 05:02
#134930
Where is it frozen, at the pedal pivot, or at the brake hub? I assume it is a drum brake?
  • krazy550
  • krazy550's Avatar
28 Apr 2007 17:22
#135059
I have had two 550s ,both had seized shafts that go threw the break hub, tapping with a hammer sometimes is a temp fix but the best fix is to take the hub off an clean out the hole an clean regrease the shaft.
  • wireman
  • wireman's Avatar
28 Apr 2007 19:37
#135115
yeah id say pull rear wheel and brake pedal clean/lube o replace anything questionable;)
