Help with tank ID?
  • wiredgeorge
  • wiredgeorge's Avatar Topic Author
Help with tank ID?
16 Dec 2005 06:35
#13446
Folks, I got a tank with my KZ1000E ST project that doesn't fit the ST. The welded on metal cups that go over the rubber dampeners on the frame to hold the tank in place are in the wrong place meaning the tank isn't meant for an ST. It also isn't meant for a KZ900 frame for the same reason. Please help me ID the tank! It is from the 80s likely as it has a locking square gas cap, same as the ST that ANY key can fit and a gas guage sending gizmo on the bottom. It has a vacuum actuated petcock as well... [file]
Post edited by: wiredgeorge, at: 2005/12/16 09:39
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Help with tank ID?
16 Dec 2005 06:49
#13450
WG. Is there a raised center portion on the top of the tank that blends in as you move posteriorly on the tank?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • wiredgeorge
16 Dec 2005 06:53
#13451
  • wireguy
  • wireguy's Avatar
16 Dec 2005 07:01
#13455
looks to me like csr tank george
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
16 Dec 2005 07:08
#13458
WG, I also (similar to wireguy) go with the K or M model 1000's. Since any key opens the gascap, it is a pre-1983, the round gas gauge cover suggests either the 1981/2 KZ1000LTD (K) or KZ1000CSR (M). Same tank for both.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • waterman
  • waterman's Avatar
16 Dec 2005 07:28
#13463
Looks like my tank to me too.
  • wiredgeorge
16 Dec 2005 07:45
#13470
The black looks original. Does the 82 LTD come in black?
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
16 Dec 2005 07:49
#13471
Yes, but I suspect it is a repaint. The original M and K models all had pinstriping of some sort.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
16 Dec 2005 08:30
#13478
here's the 82 LTD tank
  • NightRider
  • NightRider's Avatar
17 Dec 2005 09:57
#13570
CSR tank, just like mine...
