78 Z1R Front master cylinder
  • Prune1
  • Prune1's Avatar Topic Author
24 Apr 2007 18:15
#133610
hey guys im having a bit of a problem finding a master cylinder or rebuild kit for a 78 z1r. the front is leaking and Im hoping someone out there still has one alive and knows where to get the parts so i can get this bike out on the road again.
  • wireman
  • wireman's Avatar
Re: 78 Z1R Front master cylinder
24 Apr 2007 18:18
#133613
arent those connected to a cable or something like that?:S
  • JMKZHI
  • JMKZHI's Avatar
Re: .
24 Apr 2007 18:45 - 03 Dec 2008 13:36
#133619
del
Last edit: 03 Dec 2008 13:36 by JMKZHI.
  • Prune1
24 Apr 2007 20:10
#133650
yes the master cylinder is cable operated for clearance issues. i couldnt find any type of rebuild kit out there on the net. anyone got any clues?
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
25 Apr 2007 19:16
#134008
The bad news is we've not been able to find a kit either. We have talked with several companies about making them, but so far nothing has moved forward.
We have one new kit left that we are not selling - that is our template for someone to make a kit from.
In a worst case scenario, we can probably provide a kit with the correct seals on the wrong piston - and you'd have to transplant the seals from the donor piston to your existing piston.
I will say those master cylinders are very strange. I have a used one here and there is NOTHING else on the market even vaguely close to it.
  • Prune1
26 Apr 2007 20:09
#134437
hey jeff thanks for the info...please pm me with more info regarding that kit to replace the seals. Thanks!
