Stupid (*&^%*$%# luggage rack!
- ScottZ
21 Apr 2007 20:31
Ok, I picked up a universal KG luggage rack at the local salvage yard for $25 bucks, but need to extend the rails out another 3 inches or so and seems like they have too much rust inside to move them. I have soaked them in WD40, used a torch to heat them, and also tried heating them with a quick dunk in water to try and shock them loose. Any other ideas how to get these apart?
- rstnick
Re: Stupid (*&^%*$%# luggage rack!
21 Apr 2007 20:44
Hot candle wax.
I've never tried this myself, but remember reading some posts on it. You heat a candle and let the hot drippings pour down into the stuck parts. let it cool and pull apart. Or something like that. Maybe someone else knows this technique, or something else.
Coca Cola might work too.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- ScottZ
21 Apr 2007 20:46
Not sure if the wax would go in, coke is a good idea though, or some other source of acid. Thanks!
- KZErider
21 Apr 2007 20:58
PB Blaster?
81 KZ750E2(project), 81 KZ750E2(parts donor), 87 BMW K 75C - got it runnin, didn't care for it, holding for family member, 79 CB650(project) Nomad 1700, VStar 950
- kzwolfsr
21 Apr 2007 21:32
Hey Scott did you get that from Steeles. Good work man. Seeing that this is chassis, did you do you fork seals yet? I did mine today, so I can help you out, but you might need to bring your bike here, since I got the right sized bricks to block up the engine. Up to you bud!
Original man of the Caribbean
- btchalice
21 Apr 2007 21:32
i know wax works on bolts and nuts, you heat up the part and apply wax like soldering pipes
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- ScottZ
22 Apr 2007 08:15
Yep, Steeles. I finally found a big pile of them around the north side kinda hidden. I changed out my seals a couple of weeks ago, they seem to be holding up ok. I used a hydraulic floor jack and some 2x4's.
- OKC_Kent
22 Apr 2007 09:06
Cashion, OK
78 KZ650 B2 85,000+ miles
- Klaus42
22 Apr 2007 16:40
Haven't tried it yet, but have heard tell that vinegar is an old standby to break down rust...
- ScottZ
22 Apr 2007 18:49
Well, I cheated. The tube was pretty thick, so I cut a thin slot down the bottom of the outer tube with a dremel and then managed to get them apart. IF it looks too weak for my uses, I will either rivet it or when I get the use of a welder I will weld it back. Seems pretty sturdy though. Next is to fabricate a sissy bar for it.
- Pterosaur
22 Apr 2007 19:26
ScottZ wrote:
If the tube winds up being too flimsy for comfort, a couple of us have putzed around with custom arrangements for mounting boxes - might find some use looking at an old thread with pics and ideas here...
